SOUND BUFFERING ABOVE SAMPLE RATE 5
Post your feedback here
glenncos
Re: SOUND BUFFERING ABOVE SAMPLE RATE 5
Postby glenncos » Wed Feb 20, 2019 10:53 am
I tried version 1:24, my screen froze multiple times, so went back to 1:22, ill suffer not being able to go above 5 SR, until something is sorted out...thanks everyone for your input, greatly appreciated.
ON5HB
Contact:
Postby ON5HB » Wed Feb 20, 2019 4:09 pm
Question, did you try other USB ports?
If your have a lot of USB stuff connected it can hinder the throughput of the USB-port itself.
Many times USB ports are shared-bandwidth, either on the PCIe lanes other times the USB chip itself.
With devices like printers and mouses you will not notice such, but with high-bit-rate devices like the SDRplay it will cause troubles.
Programs like these: https://www.uwe-sieber.de/usbtreeview_e.html
Can help you find the problem.
Don't forget, 5M Sample-rate is a very big load on an USB-bus, if it's shared or not up to the task (happens more then you think), it will not perform at the upper limits.
Greetings,
Bas - ON5HB
glenncos
Postby glenncos » Sun Mar 03, 2019 6:22 pm
Thank you Bas I will give that programme a try and let you know
