How do you down load the RS-API ?
NeilP
Postby NeilP » Thu Mar 14, 2019 5:02 pm
Hi
This is in relation to a Raspberry Pi running on a Lite system headless.
when building the system to run Soapy Remote, you need to download the file:
SDRplay_RSP_API-RPi-2.11.1.run
or what ever its latest iteration is/
Yes there is a link on the downloads page
https://www.sdrplay.com/downloads/
but for a headless system with no web browser this is not possible..
OK< so a work around is to enable Smaba on the Pi, download on another machine and copy it across..or put it on a USB stick...but that is a pain.
Can you give the link please on the downloads page..rather than embed it within the php. so we can use...what is it...wget ?
ON5HB
Re: How do you down load the RS-API ?
Postby ON5HB » Sat Mar 30, 2019 10:14 am
You can upload it with FTP or SSH, simplest way is to download mc (midnight-commander) then make an SSH connection to the Pi.
Normally it will tunnel SFTP and transfers the file to where you want.
Then go into the Pi with SSH and "chmod +x filename" and ./filename to run it.
mc for Windows: https://sourceforge.net/projects/mcwin32/
Always done it this way, works great and simple.
To install mc on the Pi itself:
apt update && apt install mc
Very handy tool to work headless, I use it all the time.
Greetings,
Bas - ON5HB
NeilP
Postby NeilP » Sat Mar 30, 2019 5:06 pm
I did similar, I enabled Samba and used shared folder
But I was wanting to find how to download it directly to the Pi from the command line /SSH
I did eventually find the actual file location amidst the php code in the page then used wget .
ON5HB
Postby ON5HB » Tue Apr 02, 2019 9:30 am
Well, Firefox did solve the mystery as to where the file is coming from:
wget https://www.sdrplay.com/software/SDRplay_RSP_API-Linux-2.13.1.run
Tada!!! :lol:
Greetings,
Bas - ON5HB
NeilP
Postby NeilP » Tue Apr 02, 2019 12:42 pm
Looks about right
Sorry I did not post the answer, as I was not near my machine when I previously replied, was replying from the phone
