Ver 1.22 Menus
Posted: Sat Mar 24, 2018 12:46 pm
by hamrad
I see you can change the step size for each mode with a pulldown menu but how to you get that menu.
Tom
Re: Ver 1.22 Menus
Posted: Sat Mar 24, 2018 1:46 pm
by sdrplay
right click on the frequency display in the RX control window
Re: Ver 1.22 Menus
Posted: Fri May 11, 2018 4:22 am
by JJ_in_TN
This information really belongs in the manual. I searched quite a long time before finding this post. A search on "step" in the manual pdf gets you 37 hits but none related to this function.
73
Re: Ver 1.22 Menus
Posted: Fri May 11, 2018 8:03 am
by JMG
And how to store the new setting?
Re: Ver 1.22 Menus
Posted: Fri May 11, 2018 3:07 pm
by Mike2459
Pages from v1.jpg (130.52 KiB) Viewed 3765 times
AFAIK there is no provision in SDRUno to store user defined bandwidth settings.
Section 3.8 of SDRUno version v1.2 manual, not in 1.22 version!!
3.8 Changing the tuning step
Each Mode has a default tuning step size. This can be changed by Right-clicking on the RX Control frequency dial: the dial step menu will popup. Select the desired tuning step.
AM = 1 kHz
SAM = 1 kHz
FM = 5 kHz
CW = 10 Hz
DSB = 250 kHz
LSB = 250 kHz
USB = 250 kHz
