sdruno-rsp2-if ts 870 kenwood
Posted: Tue Apr 17, 2018 12:36 pm
hello to forum
i,m using the RSP2 with sdruno programm and conect to TS 870 VIA a cable to if out off this ring ...behind off this ring there is a RCA tip for output...so ihave set up SDRUNO as follow. in set in input. i chek in box IFAGC -LOW IF- gain reduction ...the next was to corect the s-meter with cal is ok now ...after i went to section rx ex ctrl and i put the numero off the agc 50 relly i dont know what is this??the issue is with this setup you can not hear signals when in the ring is 9+5 and lees ....more you have not problem ...but if you change another parametro in agc you can hear this station but after you have the intereference phenomeno and at this piont starts the problems with this programm ....p.s with console v3 i have not this issue..sorry for my english.
thanks for any help and answer...
73 SV6IEP
73 SV6IEP
