SDRuno Software Issue
WB8NUT
Post by WB8NUT » Sat May 26, 2018 4:11 pm
I am not sure what happened, but suddenly I can no longer click on a signal in the waterfall and have it to directly to that station. I had been doing it for the last week when I picked up the new Duo receiver at the Hamvention.
For example, if I have it tuned to the US AM Broadcast band, and there is a station at 700Khz, I can click on the signal and it will work just fine. Now I want to go to a station at 780Khz, I click on the signal and it goes to 800Khz. It will only go to the nearest 100Khz.
I cannot find a setting to change this. Any suggestions?
Re: SDRuno Software Issue
Post by g1hbe » Sat May 26, 2018 5:08 pm
This sounds like the bug that has the default step for AM set at 100kHz. It's due to be corrected soon, I think. You can select a step of your choice by right clicking in the main frequency display area and selecting from the menu.
WB8NUT
Post by WB8NUT » Sat May 26, 2018 9:13 pm
Thanks Andy, kept looking for a way to change the step. I'll give that a try.
Many Thanks!
W9KJO
Post by W9KJO » Mon Sep 17, 2018 1:43 am
I have looked through the manual on how to change the step and found nothing. Could someone post how to change the step. I have been using SDR UNO for sometime and never had this problem until tonight. Very frustrating that this just happened mystically tonight.
Post by Mike2459 » Mon Sep 17, 2018 2:08 am
In SDRUno 1.22/1.23:
In the RX Control Panel:
Right click inside the frequency display area.
The Tuning Step Popup will open.
Left click on the desired Step.
The current frequency step is displayed in the upper left corner of the frequency display window.
W9KJO
Post by W9KJO » Mon Sep 17, 2018 7:27 am
Thank you. that was most helpful. I never did find that instruction in the manual. I wonder how that got changed. strange thing.
W9KJO
Post by sdrplay » Tue Sep 18, 2018 2:55 pm
In the SDRuno 1.23 manual (https://www.sdrplay.com/docs/SDRplay_SD ... l_1.23.pdf) section 3.1 (p.27)
