1.3 Unable to select WFM and SWFM
I am unable to select WFM and SWFM modes in 1.3. Is this a bug? something to do with settings?
THanks much!
THanks much!
Re: 1.3 Unable to select WFM and SWFM
Please ensure that you have a high enough final sample rate. It is not possible to select to select a demodulation bandwidth that is greater than the final sample rate you have set. There is no problem with either WFM or SWFM in release 1.3 as long as have a high enough final sample rate and this has always been the case.
Hi Illllm,
Ver 1.3 works fine in Broacast FM. Here below PIC showing settings. On second PIC signal is so strong the S Meter is pinned to the right!
Cheers,
Cheers,
- ScreenHunter 334.jpg (197.19 KiB) Viewed 22597 times
- ScreenHunter 333.jpg (202.55 KiB) Viewed 22597 times
That odd...it works fine in the older version but does not work in 1.3. I will uninstall everything and reinstall. Hope that will fix it.
glovisol, how does yours shows DAB? I cannot get it to show that..
Getting access violation now using the scanner
illlm - the DAB notch filter will only appear if you have the RSP1a or the RSPDuo. Other models do not have the hardware to implement it. My RSP2 only shows notches for MW and FM.
