Saving workspace for 2 monitors
Posted: Mon Mar 18, 2019 12:55 pm
by w1egb
If I have SDRuno windows spread across 2 monitors, and save the workspace, when I restart SDRuno the windows are all on the main monitor only. Is there a way to save the workspace across both monitors? I'm using the latest SDRuno 1.3 and Windows 10 pro. Thanks for any help.
Re: Saving workspace for 2 monitors
Posted: Mon Mar 18, 2019 3:32 pm
by SDRnerd
A bit different here. Setting up the workspace on display 2, after restarting the pc all is showed on display 1.
Posted: Mon Mar 18, 2019 4:09 pm
by Delecky
Same here ,All squashed on to display 1, was fine with older versions.
Delecky
Posted: Mon Mar 18, 2019 4:12 pm
by sdrplay
As part of the ini file processing there are some rules applied that affect cross monitor windows.
We are addressing this and this will be fixed in the next release.
Posted: Mon Mar 18, 2019 4:19 pm
by w1egb
Thanks all for the replies.
Andy - can I change something in the .ini file to help?
Posted: Mon Mar 18, 2019 4:40 pm
by sdrplay
Unfortunately not, the ini file read process currently only allows windows to be displayed on the same monitor where the main window is. I am working on this and will get it fixed.
Posted: Mon Mar 18, 2019 4:48 pm
by w1egb
Again, thank you.
Posted: Wed Mar 20, 2019 8:56 am
by SDRnerd
Thanks for the reply!
