RSP2 AND SDRuno V1.3/1.31
Postby Paul » Mon Apr 29, 2019 3:17 pm
Just a straight-forward and not loaded question:
Does or has anyone else operated a RSP2 successfully in Low IF (LIF) mode using V1.3/1.31 as a stand-alone rwcwiver (with no other RX/VRX) in use), or will it only operate in Zero IF mode?
Re: RSP2 AND SDRuno V1.3/1.31
Postby Mike2459 » Mon Apr 29, 2019 4:49 pm
Yes, everyday. Version 1.3 but NOT 1.31
Postby Paul » Mon Apr 29, 2019 8:06 pm
Hi Mike
Thanks for your response.
Do you mean that it does work in low IF on V1.3 but not 1.31 or do you mean that you haven't used/tried it on V1.31?
Postby Mike2459 » Mon Apr 29, 2019 10:39 pm
No, it works on both versions. This is the primary reason I don't use 1.31: viewtopic.php?f=11&t=4369
John55
Postby John55 » Tue Apr 30, 2019 3:11 am
Hello Paul,
I have the latest SDRuno installed and have since it came out. I use a RSP 2 and I have zero problems with either setting. You can manually change from LIF to ZIF. In my case I just use LIF most of the time, but a switch to ZIF allows me to change from viewing 2 megabytes of spectrum to 10 in ZIF. LIF is meant to be used the most as it relieves errors with LO changing. Good luck.
Postby Paul » Tue Apr 30, 2019 4:40 am
Thanks Mike quite clear.
Users browsing this forum: NORVIN and 7 guests
