Sweep Control and Input Panels Missing
Aerowerx
Post by Aerowerx » Fri Dec 07, 2018 3:25 am
I received my SPR1A this morning, and have been playing with both SDRuno and SAS. But since my SMA adapters have not arrived I am limited at what I can see with just a wire stuck in the input.
However, with the SAS the Sweep Control and Input Control panels are missing. Is this because I am using a Toshiba Laptop? Anyone else have this problem.
Jim
N8EE
SteveAndrew
Re: Sweep Control and Input Panels Missing
Post by SteveAndrew » Sat Dec 08, 2018 10:46 pm
Aerowerx wrote:However, with the SAS the Sweep Control and Input Control panels are missing. Is this because I am using a Toshiba Laptop? Anyone else have this problem.
Hi Jim
When the analyser is launched, the initial window size is 1283 x 750. This may well be wider than your laptop screen. I can only suggest you try to decrease the width of the analyser window after it has been launched. Do you know what your screen resolution is ?
Best regards
Steve
Aerowerx
Post by Aerowerx » Sun Dec 09, 2018 7:34 pm
Steve,
It is currently 1366x768.
I will play with it and see what it does.
Jim
N8EE
Aerowerx
Post by Aerowerx » Sun Dec 09, 2018 8:03 pm
Steve,
I hooked up a spare external monitor to my laptop. The resolution is 1920x1080, and I can now see the controls.
Jim
N8EE
