Extended 10Mhz sweep range when ??
I have RSP1A its a fantastic tool coupled with 3Ghz noise source & return loss bridge, ok for HF and lower VHF can just manage with 10Mhz sweep, but I really really really need at times at least 200Mhz sweep, checking the centre freq of a UHF 450Mhz 5 element yagi with folded dipole greater 9dB return loss range is typically 15Mhz wide.
It would be icing on the cake to get 200 Mhz sweep range
Regards
Frank VK3ZFS
Regards
Frank VK3ZFS
Re: Extended 10Mhz sweep range when ??
I'm wondering if Steve has abandoned this project? If so would be a shame but everything he has already done is greatly appreciated.....
