Feedback for version 1.0a here
Steve,
Again thanks for the truly great product
Using the SAS software and a noise generator, I was able to see what a dramatic impact there was by making a minor inductance change on a 6M low pass filter. Trace 2 shows the filter response before I squeezed one of the coil windings closer together. Trace 1 is after. I never would have believed there would have been such a dramatic change in the filter characteristics. Without the SAS software I could only guess at what the performance of the low pass filter was.
Don
K9AQ
https://www.sdrplay.com/community/downl ... ew&id=1631
Don
K9AQ
- 6m filter with minor change in inductance.GIF (175.56 KiB) Viewed 124460 times
Tnx for reply Steve my computer screen resolution is 1440x900. Yes, the analyzer display fits vertically. My laptop is a Dell, yesterday I installed the program on a Lenovo E420 ( with its 1366 x 768 resolution) with the same results... the right half of the Controls area is missing completely and the area between the data screen and the control area has an empty space equal is size to what I would estimate the right half of the controls would require. This is true on both laptops, except the Dell laptop does show that right 1/2 over the end of the word 'frequency' at the top of the display. I hope this info helps, if you want me to try anything else... just ask. Thank you as always for your suggestions. 73, DaleThere is nothing you could do that would cause that. The analyser size at launch is 1286x754. Is this within your screen resolution ? Does the analyser fit within your display vertically ?
Steve
Hi Dalefastputt wrote:Tnx for reply Steve my computer screen resolution is 1440x900. Yes, the analyzer display fits vertically. My laptop is a Dell, yesterday I installed the program on a Lenovo E420 ( with its 1366 x 768 resolution) with the same results... the right half of the Controls area is missing completely and the area between the data screen and the control area has an empty space equal is size to what I would estimate the right half of the controls would require. This is true on both laptops, except the Dell laptop does show that right 1/2 over the end of the word 'frequency' at the top of the display. I hope this info helps, if you want me to try anything else... just ask. Thank you as always for your suggestions. 73, DaleThere is nothing you could do that would cause that. The analyser size at launch is 1286x754. Is this within your screen resolution ? Does the analyser fit within your display vertically ?
Steve
You say "The right half of the Controls area is missing completely and the area between the data screen and the control area has an empty space equal is size to what I would estimate the right half of the controls would require. "
I'm not too clear about what you are saying here. My understanding from that, is that the entire application window is being displayed, but some of the control panels are missing. Or, is the entire right-hand side of the application window missing - are the min/max/close buttons visible at the top right hand corner of the application window ?
Do the visible controls and fonts look normal ? Can you confirm your display scale setting is set at 100% ?
Do the Options and About windows display correctly ?
Lastly, I don't know what region setting you are using, if not US, could you try switching to US region and see if it makes a difference. It shouldn't, but just worth a check anyway.
A screen shot would be very helpful if at all possible.
Steve
Steve[/quote]
Hi Steve, THE BEST NEWS POSSIBLE... IT'S FIXED!! From your questions, you also figured it out!
Even though the resolution was set at 1440x900 I did not know that there was another adjustment in Control Panel - all control panel items - display; which is to "make it easier to read what's on your screen" which I had set at medium - 125% to make the desktop icons a little larger! Once I 'discovered' this, I changed the setting to Smaller - 100% (default) and BINGO ... your program now looks FANTASTIC and imho everything is PERFECT! Talk about learning something new, I NEVER had this issue with any program I ever ran until yours... I am EXTREMELY happy that the challenge has been met and it's not necessary for me to reply to your great questions!! BIG SORRY for my operator error !!!! Thank YOU for not only a GREAT PROGRAM but your attention to my challenge!
Vry 73, Dale K8ETI and yes I am in San Diego. Have a TERRIFIC Day, you just made mine!
Steve[/quote]
Hi Dalefastputt wrote: Hi Steve, THE BEST NEWS POSSIBLE... IT'S FIXED!! From your questions, you also figured it out!
I'm glad it worked out for you. I think this is a potential problem that needs to be mentioned in the manual. I'm certainly going to have a terrific day - An uninterrupted 8 hours of solid debugging to look forward too
Steve
Hi Steve,
1) I will contact Tech Support, but could you kindly explain how you define "Ref - dBm" button. Please see the attached. When the Ref is set to -40dBm, the noise floor is quite low with so many spurs. Then, setting Ref to 0dBm shows a much higher noise floor with less spurs. My understanding is that the noise floor should not be changed regardless of how you set the Ref level - which should not affect the RF gain, but the the Ref - dBm level appears to act as RF gain control. (The Ref - dBm button needs to be pushed/toggled a few times before it displays the trace correctly - maybe a bug your have already reported.)
2) Please see the attached. Although the BC/FM&DAB buttons are not inverted (blued), the measurement shows that those filters are enabled. If the Ref - dBm is set to 0dBm, the noise floor is so high that the filter curve will not be displayed - all masked.
If you have time, please try to confirm above 1) and 2). Thanks in advance!
73
Yas - JA8SCD Tokyo
Thanks for your reply.1) - I think you should contact Tech Support regarding the spurious output and higher noise floor of the RSPduo. I also get a slightly higher noise floor with the RSPduo.
2) - BC/FM and DAB buttons: At startup, the buttons are (should be) grey or un-selected, and the filters are disabled. Clicking on a filter button should turn the button blue and enable the filter. I've just checked that operation here and it all seems OK. I'll do some further checking and see if I can get the same error you are getting.
73
Yas - JA8SCD Tokyo
- -40dbm-ref.png (76.3 KiB) Viewed 124408 times
- 0dbm-ref.png (71.49 KiB) Viewed 124408 times
- bcfmdab.png (67.34 KiB) Viewed 124408 times
Hi, Firstly congratulations on the hard work that must have gone into producing such a useful piece of software as this. This looks like it will be very useful tool for me and is much appreciated. I have come across some confusing behaviour that I thought it worth mentioning. My understanding is that the reference level for the plot just sets the numerical level for the top of the plot. Is this correct or is it somehow used in the log function calculation?
I set up the spectrum analysis program with my RSP2 to look at two local stations in the FM band. I altered the reference level expecting to see just a vertical shift in the plot. Between a reference level of -80dBm and -40dBm the plots all looked as expected with just an expected shift. I noticed that the noise level changed a bit as well, but this was not large. However, for reference levels of -30dBm and -20dBm the whole shape of the plots changed.
Am I missing something or could there be a software problem? I attach the plots that I made with reference levels of -80dBm, -60dBm, -50dBm, -40dBm, -30dBm, -20dBm with the biggest discrepancies on the -30dbm and -20dBm plots.
Cheers, Mike.
Cheers, Mike.
Hi Yasja8scd wrote:Hi Steve,
73
Yas - JA8SCD Tokyo
1) The "Ref-dBm" control sets the reference level at the top of the screen. In addition, it sets the LNA and IF gains, according to a pre-defined look-up table. At higher reference levels, the total gain will be low, the lower the gain, the higher the noise floor will be. At lower reference levels, the gain will be higher, resulting in a lower noise floor. This is normal.
2) I have the filter buttons on the debug list already. They are working here, but I'll run through the code again.
Steve
Hi MikeMike H wrote:I have come across some confusing behaviour that I thought it worth mentioning. My understanding is that the reference level for the plot just sets the numerical level for the top of the plot. Is this correct or is it somehow used in the log function calculation?
The "Ref - dBm" control sets the reference level to the top of the dispaly, it also sets the LNA and IF gain controls via look-up tables. The "Offset" control just applies a vertical shift to the whole display.
I can't find the plots - did you attach them ?Mike H wrote: I set up the spectrum analysis program with my RSP2 to look at two local stations in the FM band. I altered the reference level expecting to see just a vertical shift in the plot. Between a reference level of -80dBm and -40dBm the plots all looked as expected with just an expected shift. I noticed that the noise level changed a bit as well, but this was not large. However, for reference levels of -30dBm and -20dBm the whole shape of the plots changed.
Cheers, Mike.
At lower gains (higher reference levels) the noise floor will be higher that it would be at higher gains (lower noise floor) - this is normal behavior.
Steve
I had attached the plots (or so `I was told...) I will try reattaching them in two submissions this time. It is not so much the noise floor that increases, but the shape of the curves as well, especially around marker 'C'. Many thanks, Mike.
