SDRuno to WSJT-X
An area to exchange hints and tips on various rig control software, also a place to ask the community questions if you are having problems.
LostJohn
SDRuno to WSJT-X
Post by LostJohn » Thu Jan 31, 2019 1:00 am
I have set common vir com ports, speed and Kenwood TS480.
I do see Connected status but Test on WSJT-X gives error.
Should this work? Any idea what I am missing?
Machine: Win 10 i7 16 gig Like settings work OK with other radios via HPSDR
John
Re: SDRuno to WSJT-X
Post by Mike2459 » Thu Jan 31, 2019 8:14 pm
Any other apps using CAT at the same time?
Here are my WSJT-X settings:
LostJohn
Post by LostJohn » Thu Jan 31, 2019 11:51 pm
Yes. Much like what I have. I assume that the only setting you have in SDRuno is the other end of the COM port pair.
I am using VSPM and have only re connect option set on my com-16---com-6 pair. I have tried to change the speed both up and down, matching and with system restarts. Still no joy. I will read the book to look for CAT debug.
John
