Gqrx on Linux Mint 18.1 (fairly) easy install.
Posted: Mon Jun 12, 2017 10:03 pm
Gqrx is fairly easy to install on a new Linux Mint 18.1 installation.
The available packaged version is 2.4.1 and the version you get following these instructions is 2.6.1, so worth a little command line effort. I haven't tried with 2.4.1 so don't know if it works.
I don't think it matters, but may save some head scratching later if you make sure the RSP2 is not plugged in to the computer.
I always install a few things I can't do without and I use Synaptic.
onboard - is a really nice virtual keyboard, with a useful 'Snippets' feature.
clipit - is a configurable clip-board history which I can't do without...
build-essential - install's essential programs for building from sources.
git - used to clone repositories and obtain source files to build/compile.
cmake - used to configure build environments.
I followed the instructions here http://gqrx.dk/download/install-ubuntu
As it's a new install, I didn't need to do the purge step. Can't do any harm to do those if you're in any doubt about what is already installed.
If all goes well gqrx should be available in Mint-Menu - All and you can right click on its entry to put a launcher on the desktop (or panel...). It should run and it works with a .raw I/Q stream recorded with gqrx and my RSP2 on my other partition.
Follow the SDRplay_non_Windows_Flow document available from http://www.sdrplay.com/docs/SDRplay_non ... s_Flow.pdf
But only as far as the end of Chapter 4. SoapySDRPlay.
I did the "In addition to these, in order to build CubicSDR" part, but they may not be necessary if you don't want to build CubicSDR. I'd be interested to know the result of anyone trying this part without that step. The second sudo apt-get line doesn't look like much, but both libgtk-3-dev and freeglut-3-dev have many dependencies, so I'd like to know if they're required for gqrx.
The 'SoapySDRUtil --find=sdrplay' test may result in output like the following, if you have the device plugged in:
Error: libusb_open() -3
No devices found!
So UNPLUG YOUR RSP2 and PLUG IT IN AGAIN.
Try double clicking your new (resizeable) desktop Gqrx icon and you should find your RSP2 in the list of available devices. It works, for me, with the default 'Device string' which is 'driver=sdrplay,soapy=0' as below.
It also works with just 'sdrplay'.
I had thought it would need the osmocom GNU Radio Blocks (http://osmocom.org/projects/sdr/wiki/GrOsmoSDR), but just the two Soapy parts seem enough (as well as the gqrx PPAs). No NONFREE option used anywhere.
Many thanks to the developers who put all this stuff together...
No devices found!
