RSP_TCP Server ExtIO with HDSDR in wine
nk2042
Postby nk2042 » Mon Feb 18, 2019 6:36 pm
Hi.
As a linux user I sometimes use HDSDR with wine with SDRs that have an extIO with network connection.
I tried your new ExtIO for RSP_TCP server with HDSDR in wine but it freezes at starting.
I have the same issue with the RTL_TCP ExtIO linked on the official HDSDR web site (https://github.com/hayguen/extio_rtl_tcp/releases/)
But, I use another fork of the RTL_TCP ExtIO successfully in my setup.
It can be found here: https://github.com/roseengineering/ExtIO_RTLTCP
It seems to have been developped specially for users with wine.
Do you think you can make changes in the RSP_TCP extIO plugin so it could work like this fork ?
It would add a great option for linux users for remotely acces RSP device on linux platform.
ON5HB
Re: RSP_TCP Server ExtIO with HDSDR in wine
Postby ON5HB » Wed Feb 20, 2019 4:52 pm
You can with the rsp_tcp driver-converter-server :lol:
There are several online including mine for use with websdr.org.
Here is mine: https://github.com/ON5HB/rsp_tcp
You can see it working: http://heppen.be:8091
Greetings,
Bas - ON5HB
nk2042
Postby nk2042 » Thu Feb 21, 2019 11:18 pm
Yes I know
It was the first RSP_TCP I tried successfully.
But I'm interested by the extented mode.
For now it's working like rtl-sdr dongle.
But I hope tech support will try to fix the it's extio so that it can be used with HDSDR in wine.
StandingWave
Postby StandingWave » Wed Mar 06, 2019 11:54 am
Yes, I agree that it would be good if the ExtIO for RSP_TCP server played nice on WINE. I haven't tried it with HDSDR or CubicSDR yet, but I recently set it up with SDRuno. It works fine on the local machine, but frequently 'freezes' when you try to change the IP address to a remote host. Even if you succeed in changing the IP address, it still appears to send traffic to localhost. If RSP_TCP is not running on the local host SDRuno fails to initialise properly and you can't configure it.
I appreciate that it was not targetted for Linux/WINE, but I agree that this improvement, if possible, would be worthwhile.
nk2042
Postby nk2042 » Sun Mar 10, 2019 4:35 pm
I finally managed to get it working.
I compiled RSPTCPServer on my main computer running ubuntu.
Connected my RSP and started th RSPTCPServer.
I then started HDSDR in wine with the ExtIO in the HDSDR folder.
Ant no more crash.
I think the first time the ExtIO is used you must have a RSPTCPServer on localhost otherwise it stays stalled.
I was able to change settings on the ExtIO: unchecked the autoconnect and persistent connection check boxes.
Now I'm able to connect to my remote RSPTCPServer.
iz3qfg
Postby iz3qfg » Fri Mar 22, 2019 9:46 pm
Hello, i've make a SDR server with RaspberryPi3 and a RSP1A.
Unfortunately, i have some problems with the receptions because on my HDSDR with ExtIO (setted on 0,250MSPS) the audio and the receptions is intermittent and glitchy.
The internet connection on Raspberry is a DSL with 7MBit download and 0,7 MBit upload. There is a solution for fix it? Or the connection (specially the upload) is too slow?
IZ3QFG
op. Dario
Postby Tech_Support » Fri Mar 22, 2019 10:14 pm
Hello Dario,
The problem is your upload speed. With 250 ksps and 16bit formatting, you need at least 4 Mbits/s. If you go back to 8 bit formatting (RTL standard), you still need 2 Mbits/s to use this through your aDSL as a WAN server.
iz3qfg
Postby iz3qfg » Fri Mar 22, 2019 10:41 pm
Thank you very much, i hope to have soon an upgrade of this connection.
