RSP TCP Server and Client (Windows 10)
hfaero
Postby hfaero » Sat Mar 02, 2019 2:40 am
I've downloaded the latest server and EXTIO dll and can get the server running using this command
 rsp_tcp -E -f 8867000
and get a command line response of :
 libmirsdrrapi-rsp version 2.13 found
 detected RSP model 'RSP 2' (hw ver 2)
 listening...
After copying ExtIO_SRP_TCP.dll to my Documents folder and running SDRuno.EXTIO.exe from my SDRPlay folder and selecting said dll I get:
 client accepted!
 sending RSP extended capabilities structure
 failed to start the RSP device, return (3)
 failed to initialise RSP device
 bye!
Same happens with HDSDR (SDRPlay version)
Any ideas why I can't connect or why it's failing to connect?
Thanks.
Cheers,
HF Aeronautical Specialist
hfaero
Re: RSP TCP Server and Client (Windows 10)
Postby hfaero » Sat Mar 02, 2019 3:11 am
Managed to figure out the problem.
I had to set the IP address to my machine's network IP 192.168.1.xx instead of 127.0.0.1 and while that was OK to begin with, I still got a connection error until I removed the -f option and then a connection to the client could be made and maintained.
Nice little exercise.
Cheers,
