Es'Hail2
g4rqi
Es'Hail2
Postby g4rqi » Sun Mar 24, 2019 11:34 am
Hello
I am using my SDRplay (RSP1A) and SDRuno V1.3 to listen to Es'Hail2 using an I.F of 739Mhz. I have tried to use the offset facilty so I can display the correct frequency in SDRUno at 10489Mhz using an offset of 9750000000 but I can't get it to work. Has anyone got this to work for Es'Hail2?
I have tried a much smaller offset of 1000 (Main settings, Offset, )to see how the frequency display is affected but when I enable the offset I don't notice any difference and I cannot work out what I am doing wrong. Perhaps I have misunderstood what offset does?
73 David
I2SVA
Re: Es'Hail2
Postby I2SVA » Thu Mar 28, 2019 9:31 am
Hi David,
I am facing the same problem; I tried any possible option but offset seems not to work; sometimes I get the RX panel frozen or get SW exceptions. I just sent a mail to support with Exception details. If anyone can help, wonderful!
Best 73 Alessandro, i2sva
DK8KW
Re: Es'Hail2
Postby DK8KW » Sun Mar 31, 2019 4:26 pm
Here with RSP1A and SDRPlay 1.22 the offset works. The key for me was to stop the program, then enter the offset and then restart the program again, otherwise there is no effect to the offset function.
My workaround for the frequency display is just to omit the 10GHz digits, which means, I adjust my offset in a way that when my frequency display reads for example 489.550 MHz I know that it is 10,489.550 MHz in reality (= CW beacon qrg).
Best 73
Geri, DK8KW
