Galvanic Antenna Isolators
Nulluser00
Re: Galvanic Antenna Isolators
Postby Nulluser00 » Tue Mar 26, 2019 2:04 pm
ON5HB
Postby ON5HB » Tue Mar 26, 2019 2:39 pm
But the Telenet website uses a longwire without counter, so it's normal to use extra grounding.
However with antenna's that hold their own counter like a dipole you do not need grounding, just a common-mode-choke is enough.
Like with a battery, if you don't connect both poles there will be no light :D
There are different ways to make a counter, it can be simply a mast or a fence, doesn't have to be a pin in the ground, as such you won't get a grounding-loop to handle.
I use my fence against my 160m Inverted-L and it works fine, but it's not grounded, just chocked.
Greetings,
Bas - ON5HB
