3 dB HYBRID COUPLER/ISOLATOR FOR ANTENNA SPLITTING 100 KHz -10 MHz
Re: 3 dB HYBRID COUPLER/ISOLATOR FOR ANTENNA SPLITTING 100 KHz -10 MHz
LOCAL OSCILLATOR RADIATION FROM ANTENNA INPUT
There has been speculation in this thread about the RSP's not having Local Oscillators and Mixers and therefore being devoid of L.O. radiation. A good explanation of the frequency conversion arrangement of the RSP class of Spectrum Processors is given here:
https://www.sdrplay.com/docs/SDRplay_Op ... _MW_HF.pdf
Briefly all incoming signals in the range 0-60 MHz are converted to a first I.F. of 120 to 180 MHz by a fixed L.O. operating at a frequency of 120 MHz. This first I.F. is then converted, by mixing with a Synthesiser signal (2nd L.O.) down to ZERO I.F. or to a LOW I.F. Thus very low level 1°st & 2°nd Oscillator signals may be detectable at any RSP Antenna input connector.
Local Oscillator detection was implemented using an RSP-1A driven by Spectrum Analyser software and an RSPduo driven by SDRuno. The two receivers were interconnected by means of a coaxial 50 Ohm cable. L.O. oscillator levels detected are in the order of -120 to - 130 dBm, a level testifiyng to the good quality of this design. Test results are uploaded below.
- Units not interconnected: Spectrum Analyser shows L.O. of RSP-1A & SDRuno L.O. of RSPduo
- LO Radiation 2.jpg (308.25 KiB) Viewed 28143 times
- Units interconnected
- LO Radiation 1.jpg (315.44 KiB) Viewed 28143 times
- Units interconnected & display zoomed
- LO Radiation 3.jpg (329.39 KiB) Viewed 28143 times
THE HIGH IMPEDANCE ASYMMETRICAL 3 dB HYBRID COUPLER
Core material is the same as for the 50 Ohm hybrid.
For our wideband LF 3 dB Hybrid the 560 Ohm primary winding must have a reactance Xl=560*4 > 2000 Ohm @ 100 KHz, hence:
BALANCED HYBRID TRANSFORMER T1
L= (1000*10^6)/(2*PI*10^5) > 1600uH
N > 100 * SQRT(2000/118,000) = 13 turns, With reference to the schematic diagram, we shall use 11.5 turns for N1
Secondaries N2 and N3 must be identical and at 560 Ohm impedance level. Ratio is 1.43:
N2 = N3 = 12/1.43 = 8.39 turns. With reference to the diagram we shall use N2=N3= 8. 5 turns.
Balancing resistor R1+R2 = 560/2 = 280 Ohm made with 270 + 10 Ohm.
TRANSFORMER T2 560 TO 50 OHM
Primary @ 560 Ohm: N4=11.5 turns
Secondary N5 = 12*SQRT(50/560) = 12*0.299 = 3.5 we shall use N5=3.5 turns
TRANSFORMER T3 560 TO 1KOHM
Primary @ 560 Ohm: N6=11.5 turns
Secondary N7 = 12*SQRT(1000/560) = 12*1.33 = 16 we shall use N7=16.5 turns
Wire data is given in the schematic uploaded below. Tests in next post.
- Hi Z Hybrid Schematic & Data.jpg (115.48 KiB) Viewed 28105 times
TESTING THE HIGH IMPEDANCE ASYMMETRICAL 3 dB HYBRID COUPLER
The asymmetrical hybrid performance data mentioned in the previous posts has been obtained with the test setups pictured in the screens posted below.
For the FORWARD TEST the Noise Generator output is connected to the input port, the 50 Ohm port is terminated with a 50 Ohm load and the HI Z 1 KOhm input port is connected to the RSP-1A/Spectrum Analyser via a 1 KOhm to 50 Ohm transformer.
For the ISOLATION TEST the input port is terminated into a 560 Ohm resistor, Noise Generator output feeds the HI Z port through a 50 Ohm to 1 KOhm transformer and the 50 OHm output port is connected to the RSP-1A to measure the attenuation between these two ports.
- Hybrid forward test.JPG (281.38 KiB) Viewed 28060 times
- Hybrid isolation test.JPG (223.48 KiB) Viewed 28060 times
I tested a splitter for the RSP1A.
Normal situation is T-connectors to 3x RSP1A.
I tried an splitter 5-2500MHz, splitted and the signals went down a lot.
This makes me believe that the input of the RSP1A is not 50 Ohm but very high impedance.
My splitter made a big impact on the signals, where my default T-split did not.
As such I took the splitter from the websdsr, there is no benefit at all.
My websdr does HF but upconverted with 125MHz, splitting with a proper 50 Ohm splitter made signals worse then with just T connectors.
It could help to know what splitters you are using. The RSP1a input is rated 50 Ohm, why should it be different? Why should sdrplay give wrong info & specs?
THE INPUT IMPEDANCE OF THE RSP-1AON5HB wrote:I tested a splitter for the RSP1A.
1) With reference to the blocks diagram, we see that the input of the RSP-1A is switched among input filters, depending on the frequency range selected. So input impedance must be measured within a well specified frequency range and with the RSP-1A turned on and working in the same range. The WORST CASE measurement is done with no attenuation inserted (e.g. maximum gain, position 0) because the built in attenuator subtantially improves the VSWR by providing resistive load to the input port.
ERRATA CORRIGE 23/04/19: Here below I have stated that the output of the AA30-Analyser is 0 dBm maximum. This value is what I have measured in the 3-10 MHz frequency range. However the AA30 specification states that the output can be as high as + 10 dBm, SO GREAT CARE MUST BE USED IN THE DESCRIBED MEASUREMENT, which must be done in a matter of seconds! I apologise for this mistake.
2) The measurement can be done with a Network Analyser, provided the output RF of this device is always less than or equal to 0 dBm. The AA30-Analyser outputs a constant 0 dBm signal, so it is suitable and there is no danger of damaging the RSP under test, provided you make it last a few seconds.
Input impedance has been measured in the range 3 to 10 MHz, having the RSP-1A set at 5 MHz center frequency, with DEC=1 & SR=10 MHz. The excellent results posted below show that indeed the input impedance is an accurate 50 Ohm, with minimum return loss in the order of 8 dB across the frequency range measured.
- RSP1A_Input Z_1.jpg (145.46 KiB) Viewed 28010 times
- RSP-1A_Input Z_2.jpg (144.45 KiB) Viewed 28010 times
- RSP-1A_Input Z_3.jpg (155.6 KiB) Viewed 28010 times
What do you mean wrong info and specs?sdrom33 wrote:It could help to know what splitters you are using. The RSP1a input is rated 50 Ohm, why should it be different? Why should sdrplay give wrong info & specs?
It's not a transmitter but a receiver, as such impedance isn't crucial to good workings.
Exactly what I wrote. The official published specifications by Sdrplay say: 50 Ohm input impedance. If you write in so many words it is not so, you are being unfair to Sdrplay and misleading other forum members. It is not a question of "transmitter" or "receiver".ON5HB wrote:
If you are sure that the Rsp1a input impedance is not 50 Ohm, open a ticket. Anyway if you look at the previous post you can see the rsp1a input impedance is 50 Ohm spot on.
NETWORK ANALYSER MEASUREMENTS
Shown below is what the antenna sees looking into the 50 Ohm splitter connected to two receivers in operation in the frequency range 3 to 10 MHz. It can be seen that the antenna looks at a high quality 50 Ohm termination, with a return loss always above 10 dB.
- Antenna looking into 50 Ohm splitter 1.jpg (97.41 KiB) Viewed 27840 times
- Antenna looking into 50 Ohm splitter 2.jpg (109.46 KiB) Viewed 27840 times
- Antenna looking into 50 Ohm splitter3.jpg (78.2 KiB) Viewed 27840 times
Shown below is what one receiver sees into the 50 Ohm splitter with the other receiver in operation and the antenna port connected to a long wire antenna through a 50 to 560 Ohm transformer in the frequency range 3 to 10 MHz. As can be seen, termination quality is excellent, with a return loss in the range of 10 dB or better in the frequency range examined.
- Antenna looking into 50 Ohm splitter 1.jpg (97.41 KiB) Viewed 27701 times
- Antenna looking into 50 Ohm splitter 2.jpg (109.46 KiB) Viewed 27701 times
- Receiver looking into 50 Ohm splitter 3.jpg (95.81 KiB) Viewed 27701 times
