Just hearing static
mkube402
Just hearing static
Post by mkube402 » Sat Apr 13, 2019 12:30 pm
Just hearing static on SDRuno
I installed SDRUNO – V1.31 if I tune to the local CH38 LSB, broadcast FM or NOAA Weathe i get nothing but static.
I got HDSDR working after copying over ExtIO_SDRplay_RSP1A and that is working ok
Re: Just hearing static
Post by g1hbe » Sat Apr 13, 2019 3:55 pm
Hi M. A common error is to tune to kHz instead of MHz. 'Native' frequency entry in SDRUno is kHz. If you want to use MHz, use the blue MHz button on the on-screen keypad.
If it's not that, you may have the wrong antenna selected (assuming you have the RSP2 or Duo).
