SDRuno 1.22 Released
Posted: Sat Jan 13, 2018 3:48 pm
SDRuno V1.22 has now been released. This version contains the following changes and bug fixes…
Added
• Support for 1366x768 default layout
• ADC overload detection in AGC off mode
• ADC overload acknowledgment system to avoid lockout condition
• Custom step size for each mode
• Band Button Groups (Ham Lower, Ham Upper, Broadcast)
• Two additional SP1 width presets (2560 and 3840)
• Additional menu option in memory panel to reset column widths (helps when upgrading)
• Scheduled Recording
• Auto update
Changed
• Registry reset now only clears 1.2+ entries
• SP1 Window max size supports 4K displays (3840x2160)
• Small improvements to the memory panel (panel width and field width changes)
• Improvements to the IF output mode
• UTC time fixed to 24 hour format
• Play!/Stop button colour coordinated
• Move MUTE button to make way for VOLUME label
• Moved Squelch value display to the right
Fixed
• Log10 SING error
• Aero support detection to try to prevent rendering issues
• Freezing when switching to HiZ port in gain mode
• Gain "pumping" issue when in gain mode
• Settings panels not displaying properly when "un-minimised"
• Zoomed in frequency scale drag out of bounds bug
• Noise floor measurement bug
• Improved RSP error handling
• Sample rate change causing spectrum display issues
• Device selection bug
Known Issues
• SP2 CWAFC drift issue (Zoom/window size/freq display) – will be addressed in 1.23, workaround for now is to zoom out fully in the SP2 window and then the CWAFC feature will work.
• IF output mode disabled SP1 spectrum mouse clicks – temporary issue until LO is separated from the VFO (see plans below)
Following on from the 1.21 release where we outlined the features for coming releases, we have updated our plans, as shown below. The purpose of publishing this information is to give people an insight to the development plans but it is NOT a guarantee of the exact feature line-up and we cannot give release dates.
1.23 Intermediate update
• Recording of selected signal only (either I/Q or audio) to WAV file format
• Selected signal piped to VAC in I/Q format
1.3 Major update
• Separation of VFO and LO frequency control
• Frequency scanning
1.31 Intermediate update
• Remote client for network based streaming I/Q server applications
1.4 Major update
• Addition of new API for third party plugins
Download link: https://www.sdrplay.com/downloads
Added
• Auto update
Changed
Fixed
• Log10 SING error
Known Issues
1.3 Major update
1.4 Major update
