RSP1 Linux 18.3 Cinammon Mint Install Problems
Fractal1
Re: RSP1 Linux 18.3 Cinammon Mint Install Problems
Post by Fractal1 » Mon Feb 26, 2018 10:08 pm
ok, i have uninstalled those from the software manager. removed anything to do with soapy/mirisdr and tried to remove that soapyaudio driver that keeps showing up instead of the RSP. Rebuilt soapysdr and sdrplay and still that blasted soapy audio driver shows up. I think i'm about to wipe the partition and do a fresh install of mint. We've tried our best and i think we are chasing our tails now. I'm certain i have too many bits of left over drivers or the like that giving me grief.
I will report back once i am setup again, hopefully with some better news.
Many, many thanks for you work and input.
Cheers!
Post by sdrplay » Mon Feb 26, 2018 10:11 pm
To clean out the SoapySDR modules you just need to delete this directory before rebuilding SoapySDR...
Search path: /usr/local/lib/SoapySDR/modules0.7
Fractal1
Post by Fractal1 » Mon Feb 26, 2018 10:22 pm
i've never had SoapySDR/modules0.7 showing in that directory only 2 python folders, a cmake folder and 3 libgnuradio.so and a search of that volume using "SoapySDR" shows nothing either. Something should be there i would think.
Post by sdrplay » Mon Feb 26, 2018 11:09 pm
In your SoapySDRUtil outputs, they show...
Module found: /usr/local/lib/SoapySDR/modules0.7/libaudioSupport.so (58fb1b5)
Module found: /usr/local/lib/SoapySDR/modules0.7/libremoteSupport.so (0.5.0-1c544fe)
Module found: /usr/local/lib/SoapySDR/modules0.7/libsdrPlaySupport.so (0.1.0-ca7e028)
If you have now uninstalled SoapySDR then maybe that directory has gone?
Fractal1
Post by Fractal1 » Mon Feb 26, 2018 11:27 pm
i reinstalled soapysdr and sdrplay as suggested so it should be right there. soapysdrutil --info says its there so why cant i see it?
Post by sdrplay » Mon Feb 26, 2018 11:38 pm
When you say that you can't see it, do you mean the device or the modules directory?
SoapySDRUtil --info only shows you how SoapySDR is configured.
If that report is showing sdrplay driver as being installed, then you want to use either...
SoapySDRUtil --find=sdrplay
or
SoapySDRUtil --probe=sdrplay
probe just reports more information than find. I would suggest that if you are still having problems, the best thing is to raise a ticket (https://www.sdrplay.com/support) and we can arrange to remotely connect to the machine to see what the problem is via teamviewer.
Fractal1
Post by Fractal1 » Tue Feb 27, 2018 12:05 am
yea, the modules directory. ticket sounds like a good idea, thanks.
Post by sdrplay » Tue Feb 27, 2018 2:18 pm
Just to follow up on the resolution...
I remotely connected in and removed the audio driver from the SoapySDR installation. This allowed the SDRplay driver to be seen and initial tests show it working.
Fractal1
Post by Fractal1 » Tue Feb 27, 2018 9:00 pm
Absolutely wrapped here, thank you very much. Great service! :D
em30bb
Can't get CubicSDR to find RSP1 with Linux Mint 18.3 Mate addition either
Post by em30bb » Fri Mar 02, 2018 7:03 pm
I have read this and other threads carefully regarding the CubicSDR install. I am running Mint 18.3 Mate edition and have had exactly the same experience as Fractal1. I have built CubicSDR three times now, deleted the installations twice before rebuilding it a third. This includes all the Soapy stuff. The result has been the same each time.
CubicSDR builds fine and executes, but it can't see the RSP1. There are two files in module0.7 - libremoteSupport.so and libsdrPlaySupport.so. Nothing else. No files at all that are audio drivers as indicated in the last page of this thread. The SoapySDR utility does not see the RSP1. Not sure if something should be blacklisted, but I am about ready to give up on this. The RSP1 works fine with three different Windows apps on this same computer (dual OS boot), just can't seem to make it recognized with Linux.
I have this same RSP running on a Raspberry Pi 3.
I can use CubicSDR on this computer under Linux using a rtl-sdr dongle and upconverter with no issue.
Any more ideas? Thanks.
