Page 2 of 5
Re: RSP1 Linux 18.3 Cinammon Mint Install Problems
Posted: Sun Feb 25, 2018 11:39 pm
by sdrplay
The API installation looks good. Apart from the fact that you have libmirisdr installed, you shouldn't have a problem. Which RSP do you have?
libmirisdr is an unofficial, reverse-engineered, library that neither we, nor Mirics, supports or endorses.
If you have a RSP1 then you may have interference from some kernel drivers.
It's possible that the blacklist process is different on different Linux OS distributions, but for Ubuntu you would create a file /etc/modprobe.d/blacklist.conf and put the following contents into it...
blacklist sdr_msi3101
blacklist msi001
blacklist msi2500
Save the file and reboot the system. If you are still having problems, post the results from...
SoapySDRUtil --info
and
SoapySDRUtil --probe=sdrplay
Posted: Mon Feb 26, 2018 12:19 am
by Fractal1
I am running the original RSP1.The blacklist was one of the first things i did, so thats all good. Still no joy.......
SoapySDRUtil --info
Lib Version: v0.7.0-g5626774a
API Version: v0.7.0
ABI Version: v0.7
Install root: /usr/local
Search path: /usr/local/lib/SoapySDR/modules0.7
Module found: /usr/local/lib/SoapySDR/modules0.7/libremoteSupport.so (0.5.0-f1147f0)
Module found: /usr/local/lib/SoapySDR/modules0.7/libsdrPlaySupport.so (0.1.0-ca7e028)
Available factories... remote, sdrplay
Available converters...
- CF32 -> [CF32, CS16, CS8, CU16, CU8]
- CS16 -> [CF32, CS16, CS8, CU16, CU8]
- CS32 -> [CS32]
- CS8 -> [CF32, CS16, CS8, CU16, CU8]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- F32 -> [F32, S16, S8, U16, U8]
- S16 -> [F32, S16, S8, U16, U8]
- S32 -> [S32]
- S8 -> [F32, S16, S8, U16, U8]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
Probe device sdrplay
-- Device identification
driver=null
hardware=null
-- Peripheral summary
Channels: 0 Rx, 0 Tx
Timestamps: NO
Posted: Mon Feb 26, 2018 1:25 am
by sdrplay
can you post the output of
lsusb
Posted: Mon Feb 26, 2018 1:47 am
by Fractal1
lsusb
Bus 002 Device 006: ID 1df7:2500
Bus 002 Device 003: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 002 Device 002: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 002: ID 045e:07b2 Microsoft Corp.
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 0c45:63f0 Microdia
Bus 005 Device 002: ID 0a5c:5800 Broadcom Corp. BCM5880 Secure Applications Processor
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
The first line (Bus 002 Device 006: ID 1df7:2500 ) appears to be the RSP. It's not there when i unplug the unit and run lsusb.
Posted: Mon Feb 26, 2018 2:54 am
by sdrplay
and can you post the output of
lsmod
please. SDRplay Support.
Posted: Mon Feb 26, 2018 3:01 am
by Fractal1
lsmod
Module Size Used by
msi001 16384 1
msi2500 20480 0
v4l2_common 16384 2 msi001,msi2500
ccm 20480 3
bnep 20480 2
btusb 40960 0
btrtl 16384 1 btusb
btbcm 16384 1 btusb
btintel 16384 1 btusb
bluetooth 475136 11 btrtl,btintel,bnep,btbcm,btusb
ecdh_generic 28672 1 bluetooth
gpio_ich 16384 0
dell_rbtn 16384 0
dell_laptop 20480 0
dell_smm_hwmon 16384 0
coretemp 16384 0
kvm 507904 0
irqbypass 16384 1 kvm
dell_wmi 16384 0
dell_smbios 16384 2 dell_wmi,dell_laptop
dcdbas 16384 1 dell_smbios
sparse_keymap 16384 1 dell_wmi
ir_lirc_codec 16384 0
lirc_dev 16384 1 ir_lirc_codec
serio_raw 16384 0
wmi_bmof 16384 0
rtl2832_sdr 24576 0
r820t 28672 2
rtl2832 24576 2
i2c_mux 16384 1 rtl2832
uvcvideo 77824 0
videobuf2_vmalloc 16384 3 uvcvideo,msi2500,rtl2832_sdr
videobuf2_memops 16384 1 videobuf2_vmalloc
pcmcia 57344 0
videobuf2_v4l2 20480 3 uvcvideo,msi2500,rtl2832_sdr
joydev 20480 0
videobuf2_core 36864 4 uvcvideo,msi2500,rtl2832_sdr,videobuf2_v4l2
videodev 151552 7 uvcvideo,v4l2_common,msi001,msi2500,videobuf2_core,rtl2832_sdr,videobuf2_v4l2
media 32768 2 uvcvideo,videodev
dvb_usb_rtl28xxu 36864 2
dvb_usb_v2 28672 1 dvb_usb_rtl28xxu
dvb_core 106496 2 dvb_usb_v2,rtl2832
input_leds 16384 0
rc_core 32768 6 ir_lirc_codec,lirc_dev,dvb_usb_v2,dvb_usb_rtl28xxu
yenta_socket 40960 0
lpc_ich 24576 0
pcmcia_rsrc 20480 1 yenta_socket
pcmcia_core 24576 3 yenta_socket,pcmcia,pcmcia_rsrc
arc4 16384 2
iwldvm 204800 0
mac80211 679936 1 iwldvm
binfmt_misc 20480 1
snd_hda_codec_hdmi 45056 2
snd_hda_codec_idt 53248 1
snd_hda_codec_generic 69632 1 snd_hda_codec_idt
snd_hda_intel 36864 3
snd_hda_codec 106496 4 snd_hda_intel,snd_hda_codec_idt,snd_hda_codec_hdmi,snd_hda_codec_generic
snd_hda_core 65536 5 snd_hda_intel,snd_hda_codec,snd_hda_codec_idt,snd_hda_codec_hdmi,snd_hda_codec_generic
snd_hwdep 16384 1 snd_hda_codec
snd_pcm 90112 4 snd_hda_intel,snd_hda_codec,snd_hda_core,snd_hda_codec_hdmi
snd_seq_midi 16384 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_rawmidi 28672 1 snd_seq_midi
snd_seq 57344 2 snd_seq_midi_event,snd_seq_midi
iwlwifi 221184 1 iwldvm
snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer 28672 2 snd_seq,snd_pcm
cfg80211 528384 3 iwlwifi,mac80211,iwldvm
snd 65536 17 snd_hda_intel,snd_hwdep,snd_seq,snd_hda_codec,snd_hda_codec_idt,snd_timer,snd_rawmidi,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_seq_device,snd_pcm
soundcore 16384 1 snd
shpchp 32768 0
acpi_als 16384 0
kfifo_buf 16384 1 acpi_als
mac_hid 16384 0
industrialio 57344 2 acpi_als,kfifo_buf
parport_pc 32768 0
ppdev 20480 0
lp 20480 0
parport 40960 3 lp,parport_pc,ppdev
autofs4 40960 2
btrfs 1073152 0
xor 28672 1 btrfs
raid6_pq 106496 1 btrfs
dm_mirror 24576 0
dm_region_hash 20480 1 dm_mirror
dm_log 20480 2 dm_mirror,dm_region_hash
hid_generic 16384 0
usbhid 49152 0
hid 98304 2 hid_generic,usbhid
psmouse 131072 0
firewire_ohci 36864 0
i915 1449984 4
e1000e 221184 0
firewire_core 57344 1 firewire_ohci
sdhci_pci 28672 0
sdhci 45056 1 sdhci_pci
i2c_algo_bit 16384 1 i915
crc_itu_t 16384 1 firewire_core
drm_kms_helper 151552 1 i915
pata_acpi 16384 0
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
drm 303104 6 i915,drm_kms_helper
ptp 20480 1 e1000e
pps_core 16384 1 ptp
wmi 20480 2 dell_wmi,wmi_bmof
video 40960 3 dell_wmi,dell_laptop,i915
Posted: Mon Feb 26, 2018 6:57 am
by sdrplay
msi001 16384 1
msi2500 20480 0
You can see here that the kernel drivers I mentioned above are still active and have claimed the device, so it will not be able to be used by anything else. Whether your Linux distribution has a different blacklist method or whether there is maybe a typo in the file I'm not sure.
Can you show the contents of your /etc/modprobe.d/blacklist.conf file?
Posted: Mon Feb 26, 2018 7:15 am
by Fractal1
# This file lists those modules which we don't want to be loaded by
# alias expansion, usually so some other driver will be loaded for the
# device instead.
# evbug is a debug tool that should be loaded explicitly
blacklist evbug
# these drivers are very simple, the HID drivers are usually preferred
blacklist usbmouse
blacklist usbkbd
# replaced by e100
blacklist eepro100
# replaced by tulip
blacklist de4x5
# causes no end of confusion by creating unexpected network interfaces
blacklist eth1394
# snd_intel8x0m can interfere with snd_intel8x0, doesn't seem to support much
# hardware on its own (Ubuntu bug #2011, #6810)
blacklist snd_intel8x0m
# Conflicts with dvb driver (which is better for handling this device)
blacklist snd_aw2
# causes failure to suspend on HP compaq nc6000 (Ubuntu: #10306)
blacklist i2c_i801
# replaced by p54pci
blacklist prism54
# replaced by b43 and ssb.
blacklist bcm43xx
# most apps now use garmin usb driver directly (Ubuntu: #114565)
blacklist garmin_gps
# replaced by asus-laptop (Ubuntu: #184721)
blacklist asus_acpi
# low-quality, just noise when being used for sound playback, causes
# hangs at desktop session start (Ubuntu: #246969)
blacklist snd_pcsp
# ugly and loud noise, getting on everyone's nerves; this should be done by a
# nice pulseaudio bing (Ubuntu: #77010)
blacklist pcspkr
# EDAC driver for amd76x clashes with the agp driver preventing the aperture
# from being initialised (Ubuntu: #297750). Blacklist so that the driver
# continues to build and is installable for the few cases where its
# really needed.
blacklist amd76x_edac
#mirics drivers
blacklist msi001
blacklist msi2500
Posted: Mon Feb 26, 2018 8:09 am
by sdrplay
Well that's interesting. Have you rebooted the machine since the file was updated? The drivers are still clearly active.
You may need to look into why the kernel drivers are still active even after they have been blacklisted.
We only have experience of Ubuntu. Maybe the process is different for Mint?
Posted: Mon Feb 26, 2018 8:20 am
by Fractal1
yep, i have rebooted. I really would not know where to start looking for that sort of info. I spent days finding all i could on the subject and still got nowhere. I can only hope someone using mint will this these posts. As far as i am aware, mint should not be any different, yet here we are.
If you come up with any other thoughts please let me as i can't use my radio until it's sorted. In the meantime, thank you very much for the time you have taken with me.
cheers!
