Google Map Display when using ADSB
RichardG062
Post by RichardG062 » Sat Dec 22, 2018 10:59 am
Apologies if this has been asked before but does anyone have a work around the google map display when using ADSB dump, map has 'For development purposes only' stamped all over - I guess this is down to Google?
Regards
Richard Griffith
Scannerz
Re: Google Map Display when using ADSB
Post by Scannerz » Tue Dec 25, 2018 8:56 pm
Google Maps according to Virtual Radar Servers website,
Now requires you to up load your credit card details so you can get a key to use there maps.
They will charge you to use there maps if you go over a certain download limit.
Virtual Radar now can use Leaflet style maps (free).
Though this is a problem if your plane goes over a time zone.
The plane will disappear and you will require a new map to follow that plane.
I think Planeplotter can still load Google maps for free that look fine without any water marks.
Why Planeplotter can still do this I`m uncertain.
I still prefer Virtual Radar for there some what live zoomable maps than planeplotter for viewing flights.
The Virtual Radar leaflet time zone problem is being looked into though it has not been fixed yet.
Someone else may have another solution.... cheers.
Scannerz
Post by Scannerz » Wed Dec 26, 2018 8:53 pm
If you choose Planeplotter you will need to be careful of up dating your maps to often.
As i just received this following message yesterday.
maps warn.jpg (57.78 KiB) Viewed 1889 times
