Tetra decoding
Patrick73
Tetra decoding
Postby Patrick73 » Sun Jan 13, 2019 10:13 am
Hi there !
Is it possible to decode Tetra using a RSP SDR ?
DSD+ is OK for DMR / NXDN but I still haven't found how to decode this mode (if it's possible to ...)
Thanks !
Patrick73
Re: Tetra decoding
Postby Patrick73 » Mon Jan 21, 2019 8:56 pm
So it seems it is *not* possible.
Thanks.
Re: Tetra decoding
Postby Tech_Support » Mon Jan 21, 2019 10:39 pm
It depends upon which RSP you have. The RSP_TCP server software available from a number of sources allows you to use the latest version of SDR# and its associated plugins with the RSP1 and RSP1A as it conforms to the RTL_TCP protocol. Restrictions in SDR# however prevent you from using the full range of features of these devices though.
Patrick73
Re: Tetra decoding
Postby Patrick73 » Tue Jan 22, 2019 8:00 am
Hi Tech_Support,
I'm using a RSPduo. Considering you only mention the RSP1 and 1A, I suppose it does not apply to the duo ?
Do you plan to make it possible ?
Have a nice day !
Re: Tetra decoding
Postby Tech_Support » Tue Jan 22, 2019 9:12 am
We are currently developing our own version of this software that will support all RSPs. The initial cut will only support the RSPduo in single tuner mode as it is developed around release 2.13 of the API, but it is intended to be cross-platform. Keep an eye out for announcements. Remember though that to obtain all possible features of the RSP will always depend upon support for the appropriate API calls being made within the end application and in most cases, we have no control over that.
lemano
Re: Tetra decoding
Postby lemano » Wed Jun 26, 2019 8:06 am
Hello
I confirm, with the new TCP SERVER V1.0 available here, a RSP1A, SDRsharp and tetra plugin available here (instalation is not easy, it is necessary to follow step by step the pdf)
https://forums.radioreference.com/threa ... on.370639/
it is possible to decode no encrypted informations from Tetra networks (not all but voice and some information form the network).
