dump1090
glenncos
dump1090
Postby glenncos » Sat Jan 26, 2019 6:34 pm
have downloaded the dump1090 from sdrplay for use with rsp1a on virtual radar...when i double click the file i get a quick flash of the command prompt window and then nothing..on virtual radar nothing seems to be happening either.
IZ2QDD
Re: dump1090
Postby IZ2QDD » Mon Jan 28, 2019 4:30 pm
Okay, do you follow the set up guide? https://www.sdrplay.com/docs/SDRplay_ADS-B_User_Guide.pdf
noelacramos
Re: dump1090
Postby noelacramos » Mon Jan 28, 2019 5:02 pm
Hi
Make sure you run the program in Administrator mode.
Noel
Fractal1
Re: dump1090
Postby Fractal1 » Mon Jan 28, 2019 11:46 pm
Are you running dump1090 from a batch file (.bat) containing the necessary commands?
glenncos
Re: dump1090
Postby glenncos » Tue Jan 29, 2019 4:34 pm
thanks noel...applied admin and it works..all good
