FOR FM DX Which modell RSP
HKIAA
Post by HKIAA » Thu Apr 18, 2019 12:02 pm
Is there differencies between RSP1A, RSP2, RSP2Pro, RSPduo. My main focus will be fm band dxing (87,5 - 108 MHz )
Br,
HKIAA
Re: FOR FM DX Which modell RSP
Post by g1hbe » Thu Apr 18, 2019 1:20 pm
Hi. AFAIK there are no major performance differences between the models. I use the RSP2 because I like the ability to switch between two VHF/UHF antennas and also have a Hi-z input for my LF listening.
If you are concentrating on FM broadcast, the RSP1-a would be fine. They're all good.
DaveB
Post by DaveB » Thu Apr 18, 2019 9:50 pm
One point in favour of the RSP1A is that at 6MHz sample rate and below the ADC is 14 bits which gives an extra 12 dB of dynamic range compared to the 12 bits of of the RSP2/RSP2 DUO. This should reduce the likelihood of signal overload.
David
ON5HB
Post by ON5HB » Fri Apr 19, 2019 3:55 pm
I tried the RSP1A on FM (3m band) and it's absolutely splendid.
HKIAA
Post by HKIAA » Fri Apr 19, 2019 7:35 pm
Thank you for all for valuable feedbacks !
Rgds,
HKIAA
