rsp2 and rtl_airband
bindup
Post by bindup » Sun May 26, 2019 7:11 am
hello
I'm a new owner of a SDRplay rsp2.
I only use rtl_airband on a Raspberry PI 3 and since now I only had a basic SDR usb key.
With the same antenna same wire here is what I ear with SDR key :
http://www.pilax.com/SDRkey.mp3
With rsp2 :
http://www.pilax.com/rsp2.mp3
I try to tweak gain but nothing better happened...
Do you have any advice to enjoy the rsp2 with rtl_airband ?
sudo cat /usr/local/etc/rtl_airband.conf
devices:
  type = "soapysdr";
  device_string = "driver=sdrplay,hardware=1808052311";
  antenna="Antenna A"
  index = 0;
  gain = 20;
  centerfreq = 124.575;
  #correction = -7;
  fft_size = 1024;
  channels:
      freq = 124.575;
      squelch = ( 0 );
SoapySDRUtil --probe=SDRplayplay
##     Soapy SDR -- the SDR abstraction library     ##
Probe device SDRplay
-- Device identification
  driver=SDRplay
  hardware=1808052311
  mir_sdr_api_version=2.130000
  mir_sdr_hw_version=2
-- Peripheral summary
  Channels: 1 Rx, 0 Tx
  Timestamps: NO
  Other Settings:
       [key=rfgain_sel, default=4, type=string, options=(0, 1, 2, 3, 4, 5, 6, 7, 8)]
     * ExtRef Enable - External Reference Control
       [key=extref_ctrl, default=true, type=bool]
-- RX Channel 0
  Full-duplex: YES
  Supports AGC: YES
  Stream formats: CS16, CF32
  Antennas: Antenna A, Antenna B, Hi-Z
  Corrections: DC removal
  Full gain range: [0, 47] dB
    IFGR gain range: [20, 59] dB
    RFGR gain range: [0, 8] dB
    CORR freq range:  MHz
  Sample rates: 0.25, 0.5, 1, 2, 2.048, 6, 7, 8, 9, 10 MSps
  Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
bindup
Re: rsp2 and rtl_airband
Post by bindup » Sun May 26, 2019 11:07 am
I try a lot of parameters listed by SoapySDRUtil --probe="driver=sdrplay"
It is better with :
device_string = "driver=sdrplay,hardware=1808052311,if_mode=1620kHz0";
  antenna="Antenna A"
  index = 0;
  gain = 25;
I had no luck with strong signals which are very noisy but when scanning multiple frequencies I get good sounds from distant airplanes.
Is there a way to mitigate that ?
bindup
Post by bindup » Sat Jun 01, 2019 8:35 pm
with CubicSDR on my computer, it is ok and with a very good quality.
so rsp2 is working perfectly.
now scanning on Raspberry PI with RTLSDR-airband !
I love challenges...
Post by sdrplay » Sat Jun 08, 2019 9:33 pm
There are 2 types of gain in SoapySDRPlay (you will be able to see this in CubicSDR) - one is called RFGR and one is IFGR - if you just specify a gain value, I'm not sure how that will be handled within the SoapySDR framework.
Maybe a look in the SoapySDR documentation will help to see how you can pass IFGR and RFGR to specify those gain values independently. Or see how gain= is translated into IFGR and RFGR values.
deadite66
Post by deadite66 » Sat Jun 08, 2019 9:50 pm
in the rtl_airband config you can set the gain in the devices section.
like :
gain = "IFGR=34,RFGR=4";
RSP2 Pro and RSP1A owner.
bindup
Post by bindup » Sat Jul 13, 2019 9:40 am
First of all, thanks for your responses !
Sorry for the delay, I had too much to do in the meantime.
rsp2 rocks indeed !
So many parameters to play with.
I keep you posted
Best regards
