antenna wire has come off connector
Posted: Tue May 28, 2019 8:34 pm
by Rsp1afan
Due to a loose nut the small wire has now come off the gold connector on the pcb with my 18 month old rsp1a. impossible to get the wire back with my eyesight. I presume I will have to pay for this small job to be done by sdrplay ?
Re: antenna wire has come off connector
Posted: Wed May 29, 2019 3:24 am
by AussieSusan
Find a local repair shop or Amateur Radio club.
Susan
Posted: Wed May 29, 2019 6:44 am
by sdrom33
If you look on eBay you can find ready made short cables with the female SMA connector assembled on one side & the submin coax connector on the other side. Then you just easily replace the original cable, makin sure you tighten the nut of the SMA real strong!
Posted: Wed May 29, 2019 7:20 pm
by Rsp1afan
sdrplay will send me a replacement pigtail, the pcb connector comes off easily
Posted: Sat Jun 01, 2019 9:01 pm
by jyduchene
Nice to hear SDRplay will replace the sma pigtale. How about a couple of photos when you make the repair. I suspect many of us in time will appreciate the information. Thanks, John
