Page 2 of 2
Re: Metal case?
Posted: Thu Apr 28, 2016 5:19 pm
by jherbert
I used Cramolin EMIlac (EMV-Lack) that comes as an aerosol spray. It contains silver plated copper particles and provides 60 to 65 dB attenuation. Very easy to apply, and the result even looks good. Cost per can is about 20 Euros. One can should be sufficient for 0,8 m2.
- SDRplay with Cramolin EMIlac (Small).jpg (67.18 KiB) Viewed 15648 times
Don't know if shielding makes a difference, but it is nice to know it's there, anyway.
Re: Metal case?
Posted: Wed May 18, 2016 3:02 pm
by zwoerdkop
Maybe you can find some inspiration here:
http://airspyvertersdrplay.blogspot.nl
The concept here is that the SDRplay is not a device but just a module. You have to build the device yourself, that is the idea.
Re: Metal case?
Posted: Tue May 31, 2016 8:23 am
by 9a4db
My metal box solution.... no more trouble with RF noise from PC PS.
In working position with FT817, antenna splitter, tuner, 10" PC
Re: Metal case?
Posted: Wed Jun 01, 2016 7:04 am
by DK7OB
9a4db,
very nice solution! I'm going to try it here.
Wolf, DK7OB
Re: Metal case?
Posted: Fri Oct 07, 2016 4:37 am
by xdtony
Picture below is a metal case available on eBay, it gives you another choice if you don't want to create one by yourself.
