Will CubicSDR for OSX move past V0.2.2 in my lifetime?
MiamiC70
Postby MiamiC70 » Tue Nov 21, 2017 2:02 am
Re: Will CubicSDR for OSX move past V0.2.2 in my lifetime?
Postby sdrplay » Tue Nov 21, 2017 4:06 pm
CubicSDR is actively being updated regularly by the authors. You can check out their github repository here...
https://github.com/cjcliffe/CubicSDR
(the last update was less than a day ago at the time of this posting)
It is unfortunate (and maybe a feature of the way development happens on github) that the revision number of the software doesn't increment when there are updates to the code. As far as I know the revision number is incremented when the author makes official binary builds available and essentially creates a snapshot of the design.
I hope that helps,
Paul314
Postby Paul314 » Wed Nov 29, 2017 12:40 pm
For what it's worth I've cloned the git repository and built CubicSDR and SoapySDR with SoapySDRPLAY on my mac pro running high sierra.
git clone https://github.com/cjcliffe/CubicSDR
git clone https://github.com/pothosware/SoapySDR
git clone https://github.com/pothosware/SoapySDRPLAY
I'm using `homebrew` to fight my way through installing all the needed dependancies. Sadly I didn't take notes but using `cmake` (and gui version`ccmake`) make this possible (and reading the directions on the github pages for these repos)
It's a well structured program which uses OpenGL to do the screen drawing. One thing I've encountered is the appears not to fathom non-zero IF modes very well. I think this may be due to limitations of the current SoapSDRPLAY lib. SoapySDR is a code layer that allows codes like CubicSDR to deal with a vendor neutral API.
The problem with non-zero IF modes is the change in streaming data format due to decimation? It's reasonable that this could be fixed by adding a mir_sdr_DownConvert() call to SoapSDRPLAY. Currently the git repository version makes no reference to this API call.
The non-zero IF modes may or may not be useful to me, hard to tell if you can't take a look at it.
The real goal for me is adding some measurement cursors and level readouts. CubicSDR constantly updates the spectrum displays. The dB markings are confusing unlabeled and a moving target.
