Breaking changes in SDRPlay API
Sasan
Postby Sasan » Fri Jul 20, 2018 4:39 pm
Dear SDRPlay team
Here's a request:
Could you please mention the breaking changes when you release a new API, so other developers/etc can do something about it? (although in a perfect world, it would be nice not to have any breaking changes)
While compiling an open source project, I realized that it can't be compiled, because of the recent change to "mir_sdr_StreamCallback_t" 's signature (the addition of hwRemoved parameter) in API 2.13
I didn't find any announcement regarding this change in your API release notes or the specification.
Although you contribute code to popular projects like Soapy, other less-known projects could also use these announcements to be able to react in a timely manner and update their code
Best regards
DF2HF, NM9A, EP2C
Re: Breaking changes in SDRPlay API
Postby sdrplay » Fri Jul 20, 2018 6:40 pm
You are correct, there is indeed an extra parameter required in the stream callback, which I should have made developers aware of. I've spent quite a bit of time over the last week or so having discussions with developers about the change between 2.11 and 2.13 and rebuilding as much as I can.
Any developer struggling to use the API can email me at software@sdrplay.com
The addition of the hwRemoved parameter in the stream callback defintion is the only thing that will cause compilation issues.
OH2BUA
Postby OH2BUA » Sat Jul 21, 2018 10:28 am
can't resist to remind that it would be great if SDRuno could be run without any RSP available. My RSPs are doing full duty 24/7, and I still have hundreds of gigabytes of wideband mid-winter MW IQ-recordings to listen - but I can't do that without an 'available' RSP.
73, Jukka
Postby Mike2459 » Tue Jul 24, 2018 2:18 am
Current versions of SDRSharp will playback SDRPlay I/Q files. No driver required.
OH2BUA
Postby OH2BUA » Tue Jul 24, 2018 6:21 am
Mike2459 wrote:Current versions of SDRSharp will playback SDRPlay I/Q files. No driver required.
Ok Mike, also HDSDR does that, but I would like to use SDRuno.
73, Jukka
Return to “Code Corner”
