SDRPlay server?
Toontje
SDRPlay server?
Postby Toontje » Sat Sep 08, 2018 6:56 pm
Is there something like an SDRPlay server? If not, can someone create one?
Here is an Airspy server example: https://blackcatsystems.com/software/ai ... erver.html
Here is an RTL-SDR server example: http://fyngyrz.com/downloads/CocoaRTLServer2dist.zip
Here is the source code. Can someone build an SDRPlay server?
Main reason i'm asking is because i want to look beyond GQRX and CubicSDR and start working with SrdDx.
Ton.
Re: SDRPlay server?
Postby sdrplay » Sat Sep 08, 2018 11:26 pm
I use SoapyRemote, works well for me with SoapySDR aware applications...
https://github.com/pothosware/SoapyRemote/wiki
Toontje
Re: SDRPlay server?
Postby Toontje » Sun Sep 09, 2018 9:35 am
Which apps are you using? Apparently SdrDx is not "Soapy-aware".
Ton.
Re: SDRPlay server?
Postby sdrplay » Sun Sep 09, 2018 11:02 am
SoapyRemote server and CubicSDR as the client, you could also use Gnu Radio or GQRX (if you have the right SoapySDR setup)
Toontje
Re: SDRPlay server?
Postby Toontje » Sun Sep 09, 2018 12:14 pm
Yeah, I'm looking to use SdrDx. I guess I'll have to see if there are any protocol differences between SoapySDR and SdrDx because OOTB they won't connect.
