WSJT-X
ToryGlenn
WSJT-X
Postby ToryGlenn » Thu May 02, 2019 3:37 pm
Hello, all,
I am wondering if there is any reliable 'code' out there available, maybe something like a plug-in to use WSJT-X with any of the RSP models??
I've been trying for several days to re-create the settings I had (prior to a software update) that allowed the sound output from CubicSDR (or even SDR Console) to be routed into WSJT-X audio input. I had this working about two months ago, but thanks to some in innocuous update, those settings were deleted (or set back to 'default') and now I cannot get the signal path to work properly. I've tried numerous combinations and configurations, but nothing seems to work now. So, if there's some plug-in that could be added to wsjt-x to allow SDRPlay to be recognized, that would be good.
Or, if you know anything about 'virtual cable' audio routing in either Mac or Windows, I'd appreciate hearing from you.
Thanks in advance.
ON5HB
Re: WSJT-X
Postby ON5HB » Fri May 17, 2019 4:53 pm
Have looked for it too, didn't find any.
I wanted to use hamlib but no luck.
Greetings,
Bas - ON5HB
