SDRPLAY linux commandline tools?
Re: SDRPLAY linux commandline tools?
that did the job, but still not getting adsb data out with dump1090 using the --ifile option.....
is there an easy way to implement the gain adjustment to the rawIQ:
/* adjust gain if required */
if (max_sig > MAX_GAIN_THRESH) mir_sdr_SetGr (1, 0, 0);
if (max_sig < MIN_GAIN_THRESH) mir_sdr_SetGr (-1, 0, 0);
can i use the ibuf and qbuf for it?
for (i = 0; i < count1 >> 1; i++)
sig_i = (ibuf[input_index] >> 8) + 127;
if (sig_i < 0) sig_i = 0;
dptr[data_index++] = (unsigned char) sig_i;
sig_q = (qbuf[input_index++] >> 8) + 127;
if (sig_q < 0) sig_q = 0;
dptr[data_index++] = (unsigned char) sig_q;
if (sig_i > max_sig) max_sig = sig_i;
if (data_index >= (MODES_ASYNC_BUF_SIZE * MODES_ASYNC_BUF_NUMBER))
regards
that code you've pasted comes from the ADS-B code doesn't it? That's specific to the signal we're looking for there. You probably want a more generic AGC algorithm, I could probably add a simple scheme but I'm a bit backed up with other stuff at the moment, need more hours in the day
thx
regards
any news regarding the AGC?
regards
So you will just be able to start stream and then turn AGC on/off with one line of code. We're trying to get it ready for release very soon.
well after updating the api my rawIQ wont work anymore...
./rawIQ: symbol lookup error: /usr/local/lib/libmirsdrapi-rsp.so: undefined symbol: pow
maybe you can drop some code here...thanks!
regards
