0815
Postby 0815 » Fri Mar 18, 2016 8:48 pm
thx sasan,
that did the job, but still not getting adsb data out with dump1090 using the --ifile option.....
Postby sdrplay » Sat Mar 19, 2016 1:36 am
Check this post for ADS-B support...
viewtopic.php?f=7&t=591
Postby 0815 » Sun Mar 20, 2016 8:03 am
@sdrplay,
is there an easy way to implement the gain adjustment to the rawIQ:
 /* adjust gain if required */
            if (max_sig > MAX_GAIN_THRESH) mir_sdr_SetGr (1, 0, 0);
            if (max_sig < MIN_GAIN_THRESH) mir_sdr_SetGr (-1, 0, 0);
if yes please let me know how?
can i use the ibuf and qbuf for it?
for (i = 0; i < count1 >> 1; i++)
          sig_i = (ibuf[input_index] >> 8) + 127;
            if (sig_i < 0) sig_i = 0;
          dptr[data_index++] = (unsigned char) sig_i;
          sig_q = (qbuf[input_index++] >> 8) + 127;
            if (sig_q < 0) sig_q = 0;
          dptr[data_index++] = (unsigned char) sig_q;
            if (sig_i > max_sig) max_sig = sig_i;
but what to take for:
if (data_index >= (MODES_ASYNC_BUF_SIZE * MODES_ASYNC_BUF_NUMBER))
thx
regards
Postby sdrplay » Sun Mar 20, 2016 8:40 am
you want to implement AGC?
that code you've pasted comes from the ADS-B code doesn't it? That's specific to the signal we're looking for there. You probably want a more generic AGC algorithm, I could probably add a simple scheme but I'm a bit backed up with other stuff at the moment, need more hours in the day :(
Postby 0815 » Sun Mar 20, 2016 10:55 am
yep it is from the ADSB code, ok i thought you might have something wirkong out of the box - no problem, just drop some code here when you are bored ;)
thx
regards
Postby 0815 » Sat Apr 02, 2016 3:33 pm
any news regarding the AGC?
regards
Postby 0815 » Sun Apr 24, 2016 5:28 pm
*push*
Postby 0815 » Sat Jun 04, 2016 4:39 pm
push again....
Postby sdrplay » Sat Jun 11, 2016 6:30 pm
sorry 0815 please bear with us, we're in the middle of getting the new API released. We have pushed the AGC into the API and also made the API easier to use.
So you will just be able to start stream and then turn AGC on/off with one line of code. We're trying to get it ready for release very soon.
Postby 0815 » Sat Jul 16, 2016 5:00 am
@sdrplay,
well after updating the api my rawIQ wont work anymore...
./rawIQ: symbol lookup error: /usr/local/lib/libmirsdrapi-rsp.so: undefined symbol: pow
maybe you can drop some code here...thanks!
regards
