Beta release of gr-osmosdr for Gnu Radio and GQRX
We're currently testing it here, and this is what I've done to get Gnu Radio and GQRX installed. I've also listed Jeff's instructions to build and then run Gnu Radio/GQRX with the new gr-osmosdr interface library.
Please note: These are my test build instructions. If you already have Gnu Radio and GQRX installed/running, you can probably just go down to where the gr-osmosdr build instructions are.
Ultimately, we'll work with Jeff to find a better way to deliver this to our customers, but for now, like a lot of Linux software, this requires a lot of building. This first section installs Gnu Radio and GQRX into your local directory. This should help to avoid corrupting any system installs of these applications you have.
This all assumes you have downloaded and installed the API from our website (https://www.sdrplay.com/downloads) - please make sure you get the right API installation for your system.
sudo apt install python-pip
pip install PyBOMBS
pip install --upgrade pip
pip install git+https://github.com/gnuradio/pybombs.git
instead of
sudo pip install --upgrade git+https://github.com/gnuradio/pybombs.git
pybombs auto-config
pybombs recipes add-defaults
mkdir ~/prefix
pybombs prefix init ~/prefix -a myprefix -R gnuradio-default
pybombs -p myprefix install gqrx
Build new gr-osmosdr (use whatever directory suits you for the installation instead of my ~/gr-osmosdr)...
git clone https://github.com/willcode/gr-osmosdr
cd gr-osmosdr
git checkout sdrplay2
mkdir build
cd build
cmake -DCMAKE_INSTALL_PREFIX=~/gr-osmosdr -DENABLE_NONFREE=yes ..
make
mkdir ~/gr-osmosdr
make install
Run Gnu Radio with the new gr-osmosdr...
source ~/prefix/setup_env.sh
LD_LIBRARY_PATH=~/gr-osmosdr/lib:$LD_LIBRARY_PATH \
PYTHONPATH=~/gr-osmosdr/lib/python-2.7/dist-packages:$PYTHONPATH \
gnuradio-companion
Run GQRX with the new gr-osmosdr...
gqrx
When the master gr-osmosdr is updated, the building and running of these applications should be easier. Please note that this is all still in beta, please post any feedback and comments you have. The more feedback Jeff gets, the better implementation he'll be able to deliver.
SDRplay Software Development
Re: Beta release of gr-osmosdr for Gnu Radio and GQRX
Thanks for the update.
I've already written about a list of problems I've encountered before, here: viewtopic.php?f=9&t=2798
I can confirm that it works (tested with "GRC", "gqrx" and "osmocom_fft")
I compiled and tested this new code. I still have the problem number 4 described in the above post (latest GNURadio built from source, on OS X 10.13.2)
I believe it has nothing to do with gain, but with the GRC block.
For your info: I can decode FM broadcast on GRC, which means it is working; I just have problem with the spectrum.
I've attached some screenshots (with captions): https://imgur.com/a/kfp6S
I fetched the latest changes and built it again;
I noticed a new "SDRPlay Source" is added to the source.
With the new "SDRPlay Source" in GRC (instead of "osmocom Source"), it works great now.
checking for setsockopt in -lsocket... no
checking for BN_init in -lcrypto... no
configure: error: "Error: libcrypto required."
PyBOMBS.Packager.source - ERROR - Configuration failed after running at least twice.
PyBOMBS.Packager.source - ERROR - Problem occurred while building package apache-thrift:
PyBOMBS.PackageManager - WARNING - Optional package apache-thrift failed to install. Will pretend as if it had worked.
Then I was getting this error building gnuradio itself:
[ 87%] Building CXX object gr-uhd/swig/CMakeFiles/_uhd_swig.dir/uhd_swigPYTHON_wrap.cxx.o
/home/johntron/prefix/src/gnuradio/build/gr-uhd/swig/uhd_swigPYTHON_wrap.cxx: In function ‘PyObject* _wrap_dboard_iface_set_gpio_debug(PyObject*, PyObject*, PyObject*)’:
/home/johntron/prefix/src/gnuradio/build/gr-uhd/swig/uhd_swigPYTHON_wrap.cxx:28044:15: error: ‘class uhd::usrp::dboard_iface’ has no member named ‘set_gpio_debug’; did you mean ‘set_gpio_ddr’?
(arg1)->set_gpio_debug(arg2,arg3);
/home/johntron/prefix/src/gnuradio/build/gr-uhd/swig/uhd_swigPYTHON_wrap.cxx: In function ‘PyObject* _wrap_dboard_iface_sptr_set_gpio_debug(PyObject*, PyObject*, PyObject*)’:
/home/johntron/prefix/src/gnuradio/build/gr-uhd/swig/uhd_swigPYTHON_wrap.cxx:29410:16: error: ‘class uhd::usrp::dboard_iface’ has no member named ‘set_gpio_debug’; did you mean ‘set_gpio_ddr’?
(*arg1)->set_gpio_debug(arg2,arg3);
/home/johntron/prefix/src/gnuradio/build/gr-uhd/swig/uhd_swigPYTHON_wrap.cxx: In function ‘void init_uhd_swig()’:
/home/johntron/prefix/src/gnuradio/build/gr-uhd/swig/uhd_swigPYTHON_wrap.cxx:48708:91: error: ‘ATR_REG_IDLE’ is not a member of ‘uhd::usrp::dboard_iface’
SWIG_Python_SetConstant(d, "dboard_iface_ATR_REG_IDLE",SWIG_From_int(static_cast< int >(uhd::usrp::dboard_iface::ATR_REG_IDLE)));
/home/johntron/prefix/src/gnuradio/build/gr-uhd/swig/uhd_swigPYTHON_wrap.cxx:48709:94: error: ‘ATR_REG_TX_ONLY’ is not a member of ‘uhd::usrp::dboard_iface’
SWIG_Python_SetConstant(d, "dboard_iface_ATR_REG_TX_ONLY",SWIG_From_int(static_cast< int >(uhd::usrp::dboard_iface::ATR_REG_TX_ONLY)));
/home/johntron/prefix/src/gnuradio/build/gr-uhd/swig/uhd_swigPYTHON_wrap.cxx:48710:94: error: ‘ATR_REG_RX_ONLY’ is not a member of ‘uhd::usrp::dboard_iface’
SWIG_Python_SetConstant(d, "dboard_iface_ATR_REG_RX_ONLY",SWIG_From_int(static_cast< int >(uhd::usrp::dboard_iface::ATR_REG_RX_ONLY)));
/home/johntron/prefix/src/gnuradio/build/gr-uhd/swig/uhd_swigPYTHON_wrap.cxx:48711:98: error: ‘ATR_REG_FULL_DUPLEX’ is not a member of ‘uhd::usrp::dboard_iface’
SWIG_Python_SetConstant(d, "dboard_iface_ATR_REG_FULL_DUPLEX",SWIG_From_int(static_cast< int >(uhd::usrp::dboard_iface::ATR_REG_FULL_DUPLEX)));
gr-uhd/swig/CMakeFiles/_uhd_swig.dir/build.make:70: recipe for target 'gr-uhd/swig/CMakeFiles/_uhd_swig.dir/uhd_swigPYTHON_wrap.cxx.o' failed
make[2]: *** [gr-uhd/swig/CMakeFiles/_uhd_swig.dir/uhd_swigPYTHON_wrap.cxx.o] Error 1
CMakeFiles/Makefile2:13452: recipe for target 'gr-uhd/swig/CMakeFiles/_uhd_swig.dir/all' failed
make[1]: *** [gr-uhd/swig/CMakeFiles/_uhd_swig.dir/all] Error 2
Makefile:160: recipe for target 'all' failed
make: *** [all] Error 2
PyBOMBS.Packager.source - ERROR - Build failed. See output above for error messages.
PyBOMBS.Packager.source - ERROR - Problem occurred while building package gnuradio:
Build failed.
PyBOMBS.install_manager - ERROR - Error installing package gnuradio. Aborting.
After rebuilding, I tried GRC, and it still didn't work, but I felt it was close, so I started over. First I uninstalled everything - using `which gnuradio-companion` until it returned nothing to ensure I removed all previous installations of gnuradio. Then I removed everything under ~/prefix and the build directories again and recompiled.
At this point things were working fine, but I didn't realize it, because my settings in the gnuradio recipe I built wasn't quite right. It's simply an FFT waterfall sink connected to the osmosdr source; however, I had the minimum intensity set too high. Here's that recipe in case someone else is looking for a way to debug/test their new build - just change the frequency to match your local NOAA weather station (or some similar strong signal): https://gist.github.com/johntron/c3bbed ... db903a694e
Thank you for your hard work Jeff, Andy, and everyone that conntributed! I'm going to try to get gqrx working this week sometime.
I too was getting an error in regards to 'libcrypto' and 'apache-thrift.lwr'; unfortunately, that will have to get fixed upstream on johntron's pull-request; with that being said, It is not clear for the typical Non-Technical Linux Desktop User on how one would go about "patching apache-thrift.lwr".
I just backed up the current file, installed wget, and wget the updated file " apache-thrift.lwr" that johntron so kindly provided:
mv ~/prefix/.pybombs/recipes/gr-recipes/apache-thrift.lwr ~/prefix/.pybombs/recipes/gr-recipes/apache-thrift.lwr-0.9.3
apt-get install wget
wget https://raw.githubusercontent.com/johntron/gr-recipes/patch-1/apache-thrift.lwr ~/prefix/.pybombs/recipes/gr-recipes/apache-thrift.lwr
Then I re-ran the installation.
Then ran into the same issue with UHD, but was not keen to just disabling UHD as someone else might require it; had a little time to take a deeper dive. I found that my gcc and g++ were not linked to the same source. I had to upgrade my g++ to 6, as it was 5.
apt-get upgrade g++
I just compiled this gr-osmosdr fork on my ubuntu 17.10 for use my RSP2pro with GQRX.
It's working fine: BCAM / BCFM filter can be enabled/disabled, antenna select works too, gains can be modified.
I have a DAB filter option too but it is for RSP1A only I think.
Even the bias-t can be used by adding bias=1 in the device string.
It's a great improvement.
Thank to Jeff for his work.
I have one question: Can refclock input be used ? I didn't find any option to enable it.
I followed the procedure in the Beta post above for my UBUNTU 16 machine
I got GNUradio companion to run but I get no input from the RSP2.
It says "no supported device found".
I did run the SDRplay driver for Linux
lsusb shows a device ID of 1df7:3010 when I plug it in, with no name.
SoapySDRUtil --info shows an sdrplay factory
any suggestions
N8JJ
