It works. Three RX's for two WSJTX's and one RX to play with.
Happy New Year.
Last edited by GrumpyCyborg on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
Re: It works. Three RX's for two WSJTX's and one RX to play with.
Bang for the buck...Depending on depth of pocket, processing power and how much much "real estate's available,'" a RSPDUO, a RSP2 and a RTLSDR (SCANNING) can give quite a bit of flexibility
e.g. 2 X HF & 2 X V/UHF or 3 X Hf & 1 X V/UHF or 4 V/UHF (not too shakey).
SP displays available at back.
- 2019-01-01 (1).gif (401.97 KiB) Viewed 13710 times
GrumpyCyborg wrote:
Happy New Year.
Hallo GrumpyCyborg
Can you tell be more about the set-up please. How do you interface between SDRUno and WSJTX? What antennas are you using? If you use VACs which "brand"? What computer and display spec? etc.
With SDRuno, if using multiple RXs then you really also need to use multiple screens. I am running an Intel core i7 6700 cpu with Nvidia GTX960 video and 2 x 24" monitors. This enables me to run my RSP2 receiving 6 L-Band AERO channels, SDRuno with 6 VRX feeding through 6 virtual audio cables to 6 copies of MultiPSK, with the data feeding into AERO-Display as under:-
Mike
Mike
Last edited by mikesimpson55 on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
