Indoor dual band antenna
mikeladd
Post by mikeladd » Fri Jan 18, 2019 11:21 pm
Looking for dual band (2m, 70cm) indoor antenna options. Can't decide if I should use a roll up J-pole behind the blinds or if something else is available.
This will be a recieve only antenna. I have this one bookmarked.
http://www.n9tax.com
Thank you,
Mike
Roger
Re: Indoor dual band antenna
Post by Roger » Sat Jan 19, 2019 12:35 am
J-poles don't like to be too close to other objects - they detune easily.
How about a mobile 2M/70cm dual band mag mount antenna stuck on a cookie sheet. Not great but easy to setup and you can go mobile if you have the occasion.
Roger
mikeladd
Post by mikeladd » Sat Jan 19, 2019 1:20 am
That works. I could easily mount it on a camera tripod like I do with the loop.
