Booming LW sig from N. Africa
Post by Mike2459 » Fri Mar 08, 2019 12:51 am
252 KhZ R.Alger into EM99 from 0000Z onward
R Alger.JPG (232.74 KiB) Viewed 7235 times
Re: Booming LW sig from N. Africa
Post by g1hbe » Fri Mar 08, 2019 8:41 am
It's amazing. There's a temptation to think that LW signals are very stable and not affected much by conditions because of their low frequency, but things like this make you think again!
Post by Mike2459 » Fri Mar 08, 2019 3:04 pm
Local and regional noise levels were low. No crashes heard here from thunderstorm activity. There was also a sunspot facing earth yesterday that raised the solar flux somewhat. I wonder if that could have been a factor? 2019 has seen 48 days with no sunspots facing earth according to Spaceweather.com.
CobraJohn
Post by CobraJohn » Fri Mar 08, 2019 4:42 pm
Are you sure this is not RTE Radio 1 from Ireland which also transmits on 252Khz?
Post by Mike2459 » Fri Mar 08, 2019 7:32 pm
Pretty sure it's not RTE
Most shows are in French with some Arabic.
fotoralf
Post by fotoralf » Fri Mar 08, 2019 11:11 pm
Besides, the Algerians are transmitting with 1500 kW - yes, that's 1.5 megawatt - or 750 kW during nighttime and RTÉ with 'a mere' 300 kW.
Ralf
DL9KCG
