Saving workspace for 2 monitors
w1egb
Post by w1egb » Mon Mar 18, 2019 12:55 pm
If I have SDRuno windows spread across 2 monitors, and save the workspace, when I restart SDRuno the windows are all on the main monitor only. Is there a way to save the workspace across both monitors? I'm using the latest SDRuno 1.3 and Windows 10 pro. Thanks for any help.
SDRnerd
Re: Saving workspace for 2 monitors
Post by SDRnerd » Mon Mar 18, 2019 3:32 pm
A bit different here. Setting up the workspace on display 2, after restarting the pc all is showed on display 1.
Delecky
Post by Delecky » Mon Mar 18, 2019 4:09 pm
Same here ,All squashed on to display 1, was fine with older versions.
Delecky
Post by sdrplay » Mon Mar 18, 2019 4:12 pm
As part of the ini file processing there are some rules applied that affect cross monitor windows.
We are addressing this and this will be fixed in the next release.
w1egb
Post by w1egb » Mon Mar 18, 2019 4:19 pm
Thanks all for the replies.
Andy - can I change something in the .ini file to help?
Post by sdrplay » Mon Mar 18, 2019 4:40 pm
Unfortunately not, the ini file read process currently only allows windows to be displayed on the same monitor where the main window is. I am working on this and will get it fixed.
w1egb
Post by w1egb » Mon Mar 18, 2019 4:48 pm
Again, thank you.
SDRnerd
Post by SDRnerd » Wed Mar 20, 2019 8:56 am
Thanks for the reply!
