Access Violation During Shutdown
brush73
Post by brush73 » Thu Mar 28, 2019 7:15 pm
When shutting down, the Recorder and Scanner windows stay open along with the following Access Violation popup appearing:
Annotation 2019-03-26 200530.jpg (13.37 KiB) Viewed 9359 times
. . . John (WA3CAS)
brush73
Re: Access Violation During Shutdown
Post by brush73 » Tue Apr 02, 2019 12:42 am
I found a simple workaround to avoid the Access Violation popup. To shutdown, first manually close the Recorder and Scanner modules, and then close the Main module, which will shutdown everything else.
. . . John (WA3CAS)
