vac for duo
M0RON
vac for duo
Post by M0RON » Wed Apr 03, 2019 10:28 am
[quote][/quote]Hi all,
Waiting for my duo to be delivered, main interest is wspr.
My question is, how many vac are needed for the duo?
I'm working my way through the manual but not the same as having a unit in front of me.
My username is my amateur callsign.
MTG
Re: vac for duo
Post by MTG » Fri Apr 05, 2019 11:53 am
An antenna in to each tuner and a VAC out from each audio output.
Do you intend to use WSJT?
Mike
M0RON
Re: vac for duo
Post by M0RON » Sun Apr 07, 2019 1:42 pm
Hello Mike,
Yes, wsjt was the program I'd most likely use. So I'd need 2 vac to use both inputs on different bands at same time?
mikeladd
Re: vac for duo
Post by mikeladd » Wed Jun 05, 2019 7:34 pm
I assume you want to monitor two separate areas of the spectrum using WSJT-X
You need to create 2 cables.
Each instance of Uno (x2 for dual tuner mode) should be assigned a cable (RX CONTROL/SETT button/OUT tab)
