RSP 1 and Sodia
JimPa
RSP 1 and Sodia
Post by JimPa » Sun Apr 14, 2019 2:01 pm
First of thanks to all involved in releasing V1.31 of SDRuno so quickly after the problems with API driver.
While all this was happening, I was getting used to Sodia SDR V1 software for digital radio mondiale decoding
With the new API drivers I get the following error message:-
FAILED TO LOCATE API Registry entry HKEY.LOCAL.MACHINE\SOFTWARE\SDRplay\API ERROR
Has anyone found a work-around for this?
Re: RSP 1 and Sodia
Post by sdrplay » Tue Apr 23, 2019 9:29 am
If you mean Sodira, then I believe that works on an ExtIO dll - if you have RSP1, RSP1A, RSP2 or RSP2pro then you will need the API 2.13 installed. The ExtIO plugins for those devices requires it. Check that you have that version of the API installed and the latest ExtIO plugin.
JimPa
Re: RSP 1 and Sodia
Post by JimPa » Mon Apr 29, 2019 7:01 pm
Thank you Andy
hmm, yes Sodira, not Sodia as I spelt it
I cleared out all the previous "SDRplay programs, drivers etc. when SDRuno3.1 came out, as I did not know if the drivers could be installed at the same time
SDR console version 3 needed reinstalling as I had removed all the C++ libraries as well....
Thanks again
