sdr play
Posted: Wed Jan 23, 2019 6:37 pm
by JACQUES F0FTL
Bonsoir.
je possède un sdr play rsp2, il fonctionne trés bien avec sdruno par contre j'ai des problémes avec sdrsharp il ne prend pas sdr play.
Re: sdr play
Posted: Wed Jan 23, 2019 7:34 pm
by Tech_Support
From google translate for non French speakers:
"Good evening.
I have a sdr play rsp2, it works very well with sdruno cons I have problems with sdrsharp it does not take sdr play."
Hello Jacques,
SDRsharp no longer supports SDRplay products because the authors of this software sell their own competing hardware (Airspy). The last version of SDRsharp to support the RSP line of products was release 1361 which was the last version to support the ExtIO interface.
It is possible to use the latest versions of SDRsharp with RSPs if you use the RSP_TCP server software which is compliant to the RTL_TCP protocol, but some functions will be missing because of missing calls within the client application.
