Waterfall signal/peaks disappeared - hit wrong button?
K4ZOT
Post by K4ZOT » Mon Aug 12, 2019 7:15 pm
I need someone's help to restore my previously working waterfall signal. I hit the wrong button and now the waterfall and signal peaks disappeared. I cannot determine what button or setting I may have changed to cause this issue. Any help would be appreciated.
Glenn
K4ZOT
Re: Waterfall signal/peaks disappeared - hit wrong button?
Post by Paul » Tue Aug 13, 2019 5:20 am
Hi Glenn
It always helps folk to try and help if you are able to post an image of your workspace.
However, "just a real shot in the dark:"
Select SP1 on your Main panel, then the screen should be "somewhere" on your workspace, depending on how you had it arranged and sized (it can always "hide" behind another panel until you re-select it).
Best Wishes
