Feedback for version 1.0b here
Re: Feedback for version 1.0b here
Steve has addressed the locale issue and the installer has been updated on our website. Same download, just do it again if you had locale issues.
Are you able to provide any details - Are there any error messages displayed ? Can you reproduce the crash conditions ?
Best regards
Steve
There are no gain controls available. Setting the reference level sets the LNA and IF gain reductions according to lookup tables.
Best regards
Steve
Hi BrianBrian VK6LO wrote: ↑Thu Aug 22, 2019 12:19 amSteve
The beta version operates on Vista apart from scrolling the centre frequency
Mouse scrolling does not change any digits however the digit/s can be hi-lighted (and flash) with the mouse and changed by keyboard arrows and also new frequency can be entered from the keyboard
Early days but looks good - thanks
Brian
Vista does not seem to recognize the scroll wheel. As you mention, keyboard entry mode is possible.
Best regards
Steve
Err... The control already works as you have suggested. Check the manual.
The analyser tunes in steps of 1, 2 or 3 MHz depending on selected IF and bandwidth. It is possible to get an extremely fast update at 10MHz bandwidth, but the output will be Zero-IF and will include the DC spike in the middle of the spectrum.someYguy wrote: ↑Thu Aug 22, 2019 5:05 amI also find that at present, I like the spectrum display in SDRUno better because I can use & control FFT averaging regardless of frequency span, up to the full 10 mhz. I do realize that for large spans i.e. > 10mhz , averaging would be too slow and so that is the purpose of the new video filter. Bravo and thank you for that. Also, the spectrum display in SDRUno updates VERY quickly, even at 10mhz span. I think that SAS ver 0.9 did this also. So would be good in SAS if the display could update that quickly when using spans up to 10mhz, and then scan as it does now for spans higher than that.
Best regards
Steve
Re: Waterfall Mode?
Hi Ralf
Unfortunately the waterfall mode has been removed.
Best regards
Steve
Thank you, it works on the German Windows 10 system now!
Best 73
Holger 'Geri', DK8KW
Best 73
Might be intended to be working that way, but not here on my Windows 7 machine. No mousewheel function and arrow keys are unreliableSteveAndrew wrote: ↑Thu Aug 22, 2019 10:48 amErr... The control already works as you have suggested. Check the manual.
![Sad :(](./images/smilies/icon_e_sad.gif)
Works well here...someYguy wrote: ↑Thu Aug 22, 2019 4:30 pmMight be intended to be working that way, but not here on my Windows 7 machine. No mousewheel function and arrow keys are unreliableSteveAndrew wrote: ↑Thu Aug 22, 2019 10:48 amErr... The control already works as you have suggested. Check the manual.
Hover the mouse over each digit and the digit under the mouse will have a grey box around it - at that point you can use the mouse scroll wheel to either increase or decrease the value. You can also click on the digit and then the grey box starts to flash, now you can use the up and down arrows on the keyboard as well.
Hope that helps explain how it works. I can't explain why it may not work on certain systems.
sdrplay wrote: ↑Thu Aug 22, 2019 5:32 pmWorks well here...someYguy wrote: ↑Thu Aug 22, 2019 4:30 pmMight be intended to be working that way, but not here on my Windows 7 machine. No mousewheel function and arrow keys are unreliableSteveAndrew wrote: ↑Thu Aug 22, 2019 10:48 am
Thank you Andy but still not working as intended. I am a software developer myself and I use similar controls in some of my applications, including a custom frequency selector which I wrote myself for use in a transceiver CAT control program so I'm familiar with how it should work but I don't know either why it doesn't work here. Could be something to do with my computer hardware or mouse driver I suppose. Oh well no worries.
