SDR# 1361 Frequency Manager
Hi there.
I am hoping some one can help me with this.
I am using my sdrplay with sdr# 1361 (plugin version from here)
I want to be able to back up my saved frequencies from the frequency manager but I do not know where the config file would be for it? I have searched the main folder and dug around my C:/ drive.
Does anyone have the answer?
Regards
Dos
Regards
Dos
Re: SDR# 1361 Frequency Manager
There are 3 freq mgr that I know.
-- "naive" sdr# freq mgr (this save your freq in frequencies.xml in the same dir of your sdr#.exe)
-- "vasili" freq mgr (this save your freq in frequencies.xml (little format diff from the above) in the same dir of your sdr#.exe)
-- "Jeff Knapp" freq mgr (this save in a SQLite db and you can "override" the directory/name of the file. By default it goes in the "user" folder tree according to the sys op you use, e.g. in win7 c:\USERS\<username>\etc etc)
Which one you want to backup?
bye
bye
Hi there.
Thanks for the reply.
I have the SDR# 1361 with plugins which I downloaded from this site.
It looks like this
Regards
Dos
It looks like this
Regards
Dos
It gets saved as frequencies.xml in same folder as sdr# is
Hi there.
I have reinstalled windows due to having an issue with graphics card driver and reinstalled my sdr# and now the xml file is appearing which is brilliant but previously it was not showing up. It must have been a bug on my machine but the good news is now I can back up all my frequencies.
I felt naked without my backup
Thanks again for the input everyone
Regards
Dos
Regards
Dos
- Contact:
I have a complete set for you with all working plugins nothing to install just unpack and play, if you give me your email i will send you a link to download the zip.
Cheers
Cheers
Hi Qosmio:
Could you mind send me a copy of SDR# 1361 with all working plugins? Thank you!
mousegg@yahoo.com
mousegg@yahoo.com
Anybody has the ADSB# Plugin and Audio Waterfall Plugin for SDR# 1361?
Thanks.
Thanks.
