M0DEP
Post
by M0DEP » Sat May 30, 2015 12:27 am
Hi Paul,
Thanks for the info. Yeah any updates would be much appreciated. As far as PPM goes, mine is fine as well at least for voice, however I was experimenting last year with an RTL dongle with modded temp controlled TCXO using the dongle as my receiver and my FT-847 as the transmitter to do digital modes, so for me matching the dongle exactly to my radio is critical. The Same will be required when I try it again with the SDRplay as digital signals are very narrow and a few hertz off frequency can make a big difference compared with voice. Just for your info, I was doing this using an ELAD switch box (RX/TX Automatic exchanger) which basically Isolates the SDR when you transmit (both RF and AF) and in conjunction with Cat cable and Omni rig makes a great combination. Its awesome to see a signal in the waterfall, click it and then work it. No dial turning required
Anyway I digress and way past bedtime
Keep us posted on any info Paul
Russ (M0DEP)
M0DEP on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
ON4LL
Post
by ON4LL » Thu Jun 11, 2015 4:45 pm
Ohhh
lucky I've read this ... I was wondering why I needed to start and stop all the time.
Hope Simon is doing an update for this, happy to donate if it works
![Smile :-)](./images/smilies/icon_e_smile.gif)
ON4LL on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
zanco
Post
by zanco » Sat Jul 18, 2015 12:47 pm
After installing the latest build ( 2178 ) does one still have to install the EXTIO installer into this folder or is that necessary for SDR# and HDSDR ?
Ben - PE2BZ
zanco on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
mikeladd
Post
by mikeladd » Tue Jul 21, 2015 5:15 am
The ext/io is for hdsdr and sdr# and any other front end that supports the ext/io. Sdr-console does not use this
mikeladd on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
jimcking2
Post
by jimcking2 » Tue Sep 15, 2015 6:41 pm
I am still having the same problems mentioned hear even with the SDR Console V2.3 2194. Is it working for other people?
Jim K.
jimcking2 on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
Post
by jon » Tue Sep 15, 2015 9:20 pm
We at Sdrplay have a call booked this week with Simon Brown at SDR Console to get the latest API working I.e. Removing the gap and allowing tuning across band edges.
jon on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
