SDR Related road map - comments
DaveB
Post by DaveB » Fri Aug 02, 2019 12:21 pm
Could the SDRPlay team see their way to add the following functionality to the RDS features. Maybe add to the road map in time for the 2020 Es season.
1. A logfile of date+time, frequency, PI code, PS - at minimum. This would give fully unattended monitoring for FM-DXing using the scanner. The file name would be in following form e.g SDRUNo_RDSLog 2019-07-29. Entries would be appended when a pi code is received.
2. A 'simple' change to the reset of the RDS - automatic reset on a change of frequency. Currently when DX ing you have to manually reset to avoid confusing a pi code from a previous frequency.
BTW the RSP I purchased at the end of Dec 2014 is still working fine.
David
