rsp_tcp - access to all features ?
Posted: Thu Aug 22, 2019 10:01 am
Hi all,
I have a recently purchased rsp1a and run it via a remote server running rsp_tcp in Extended mode. I use HDSDR or the old extio version of SDRuno. My question is about what options are available via the ExtIO dll. On the rsp_tcp server guide, it says 'in extended mode, all of the rsp's feature become available'. In looking at the rsp1a datasheet, I can see lots of filters available e.g. 2-12MHz band pass, 1000MHz high pass and MW filter 660-1550KHz etc etc. These do not appear in the RSP TCP ExtIO panel. There are BC ( broadcast ) and DAB filters available, with AM and RF displayed but permanently greyed out. So :
1. Should I expect to see all features available on the RSP TCP ExtIO panel or are they automatically configured depending on the frequency you select or does the rsp_tcp server not make them available ?
and
2. Why are AM and RF permanently greyed out ?
Kind regards,
Jem.
and
Kind regards,
Jem.
